Old 01-02-2016, 11:16 AM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
Default Does 65 GTO / Lemans front license plate impede airflow at high speed?
Removing radiator to have it sealed up and improved by a local shop. While draining the coolant and removing lower hose it became obvious that the license plate & bracket hang down a solid 2.5 inches below the front bumper and would be blocking some airflow to the radiator at speed. At a minimum it would create unnecessary turbulence of the airflow.
Anyone ever play around with and without the plate or have a point of view on these topic?
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
Old 01-05-2016, 02:29 AM
You have to be kidding. The front of your car is shape like a brick I don't think the lic. plate would much matter.
Old 01-05-2016, 07:42 AM
chrisp chrisp is offline
Tough one
Old 01-05-2016, 08:49 AM
Jim Doran's Avatar
I agree, diminishing returns, but if you take an actual look, the plate hangs several inches down into what would be a clear airflow into the radiator. I'll try and take a pic.
Trouble is it would be near impossible to measure with and without difference.
-Jim Doran-
2016 Chevy SS; Sold
2008 Infiniti G35x
Old 01-05-2016, 10:47 AM
Keith Seymore's Avatar
We do this kind of measurement all the time at work; it is directionally incorrect but not measureable (or very insignificant). We generally define the amount of opening in square inches (or square millimeters these days) and quantify how much is being blocked off.
The majority of the air is entering through the upper grille and the bumper slots anyway. The fact that the plate is hanging down in open space (as opposed to a constrained space) also minimizes its effect. When the plate is blocking one of the upper openings then it becomes more of a contributor (like if you mounted it on top of the GTO emblem, for example).
K
'63 LeMans Convertible
'63 Grand Prix
Old 01-09-2016, 08:12 AM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
A 65 front bumper looks similar to a 67.
Mounted the front plate with it hanging below the bumper opening.
Two pics with the plate mounted. Red car is mine.
ID:	417731   Click image for larger version
Scott
If you always do what you always did
You always get what you always got
Old 01-10-2016, 11:32 PM
Hooter's Avatar
Hooter Hooter is offline
I've been 135 with my front plate on
67 Bonneville ragtop
Old 01-11-2016, 12:17 AM
Jim Doran's Avatar
Remove the plate and you'll hit 137 !
-Jim Doran-
2016 Chevy SS; Sold
2008 Infiniti G35x
Old 01-11-2016, 10:37 AM
John62 John62 is offline
The A/C cars have a radiator that hangs down 2 inchs lower and can be seen hanging below the bumper. In this case I bet it would have some affect on cooling.
Old 01-11-2016, 12:22 PM
Mine looks pretty much even with the bottom of the bumper:
'63 Grand Prix
Old 01-11-2016, 04:09 PM
So does Ed Lis's;
Jim - do you suppose you have the wrong bracket?
K
ID:	417942   Click image for larger version
'63 Grand Prix
Old 01-11-2016, 06:27 PM
So does Ed Lis's;
K
As I see it, the bracket in this pic is upside down. I believe if you put the bracket on correctly the plate does hang well below the bumper. Jim's is likely correct. They can and most people do install it upside down because it looks correct but probably blocks more air because it blocks the gap between the top and bottom section of bumper. I hope this comes out the way I think I am saying it.
Old 01-11-2016, 06:30 PM
I think this is what Pontiac originally intended.
http://forums.maxperformanceinc.com/...1&d=1452551404
Old 01-11-2016, 10:08 PM
Chris65LeMans's Avatar
This is right, I believe. When I bought a repro bracket, I didn't like the look of the plate hanging down, so I put the bracket on upside down.
Old 01-12-2016, 12:04 AM
Jim Doran's Avatar
John, Chris you are correct. There is a pocket on the bracket that should be mounted at the bottom. The plate then slips into this pocket and is screwed in the lower 2 holes.
Keith, I respectfully suggest your plate might be mounted wrong or with a different bracket. I also remain convinced it disrupts airflow under the bumper.
These pics should help.
ID:	417989   Click image for larger version
-Jim Doran-
2016 Chevy SS; Sold
2008 Infiniti G35x
Old 01-12-2016, 07:34 AM
Very interesting.
I don't believe mine has ever been apart. A factory mistake on an early built car, perhap? (My car was built September 18th of 1964, in Pontiac Michigan).
Ed's car has 4200 miles and has never been restored (March built Kansas City car). I can't comment on if any changes have been made to his car beyond that.
K
A couple pics of Ed's car with no plate attached:
ID:	417999   Click image for larger version
'63 Grand Prix
Old 01-12-2016, 07:37 AM
I understand the way you are saying it, and agree, that from an airflow design perspective it is a greater offense to block the area in the opening of the bumper than it would be to allow the plate to hang down into open space.
K
'63 Grand Prix
Old 01-12-2016, 07:47 AM
Anybody know how the design of the '64 bracket compares?
Looks like there is precedence for mounting it "up high".
K
'63 Grand Prix
Old 01-15-2016, 10:05 AM
HWYSTR455's Avatar
An air dam (on the core support, below the radiator) would negate any impact the plate would have on air flow, especially at speed. And it wouldn't have to be very big/much area.
Old 01-23-2016, 09:39 AM
Jeff Hamlin's Avatar
Talking The end all to this dilemma...
While looking through old photo files for something I came across some old shots from a past club cruise and laughed when I saw this pic.
I forgot about this quick change front end treatment and thought it went well with this post
Don has owned his '65 since new so as anyone who has something that long they are bound to personalize it.
He made an air-dam that he easily can put on and take off when he is in the mood for a change.
