What Battery?
Hey Everybody,
What single 12v. battery are people using? Thanks Again, Craig |
I'm using an Odyssey.
i am using a braille
it's a big mofo, but no hot starting issues with locked timing or anything expensive too, but no problems with it but needed a different charger for it |
Been using same red top Optima for almost 15 yrs now.
Optima red top here too.
The yellow top Optima is supposed to be better, if you don't run an alternator.
http://www.ebay.com/itm/Optima-8014-...-/161400724653 But, if you got a good mini-starter, and don't wanna spend much on a batt, an 800-850 CCA old style batt will still crank most of 'em. The Deka 778DT has 850cca, and sells for less than $100 at many local batt outlets. Bought one for my tractor. http://www.ebay.com/itm/DEKA-778DT-B...-/331605608843 Last edited by ponyakr; 01-28-2016 at 06:24 PM. |
Braille Lightweight
BRL-B2618 12V works on a 505 15 to 1 CCR. Have not had any starting issues.
505 KRE HP head 2x4 HP 1000s 60' 1.33, 5.78 @ 120.88MPH in 1/8 9.11@149.8MPH in 1/4 |
I run A yellow top optima for 7 years.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
I use an alternator, mini starter and a red top but still have some trouble in staging.
Thanks, Craig |
Been using an Odyssey PC925 in the trunk of my '66 GTO for the last 5 years and still cranks the 11.4:1 428 very well. Unless you think the extra weight of a "conventional" battery will help traction, these Odyssey's are a great way to go. Can also mount on the side as shown below.
I have an AGM Superstart that has worked perfectly in the 4 years I have been using it in my Daily Driving Formula w/ 455. I've parked the car for a week or two at various times when traveling. Always starts and does so with authority.
http://www.oreillyauto.com/site/c/de...0423&ppt=C0005
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
Braille 2015..works well with my mini starter..in my street car
why not go 16v and all your starting issues will be over
Optima yellow top with a alternator
Thanks guys I think my budget will dictate and will test to I buy a used AGM battery.
Craig |
I just replaced my IMI Hi-torque starter with a Powermaster Ultra Torque starter. The ultra has twice the output capacity, and it showed it yesterday after I installed it and cranked my engine repeatedly with a single Optima redtop. I have an adjustable rotor for installation too, assuring the rotor is phased correctly. I'm going to upgrade my safety cutoff switch, remote solenoid and install a new alternator next weekend. I'll let you know if I see any improvement in the staging lanes this year,
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
