Old 02-01-2016, 01:38 AM
1973T/A's Avatar
1973T/A 1973T/A is offline
Default Another 70 t/a resto underway
Well I finally got started on my Lucy blue t/a. Going to have lots of questions as I go! First question I have is on the column it has the linkage for an automatic on the column. I have never seen that before is that normal being its a 4 speed car.
Old 02-01-2016, 07:25 AM
It is used for the same thing as the automatic.
It turns the collar on the column to lock the steering in Park and for the reverse lights.
Old 02-01-2016, 09:34 AM
1973T/A's Avatar
Oh sure that makes sense! Part that threw me is that it wasn't hooked up and just seemed odd that it was there.
Old 02-02-2016, 03:46 AM
Formulabruce's Avatar
"Back drive Linkage" , Lucky to have it present. If this car had headers , it would be missing
" Long may we DRIVE !"
Old 02-02-2016, 08:27 PM
1973T/A's Avatar
Another question I have.. The car is all numbers matching and I want to be able to drive the car and not have to worry about it for a lack of a better term. Would it make sense to put the original engine on a shelf and put in a 72 ho that I have?
Old 02-02-2016, 08:38 PM
have you considered finding a 400 4-bolt block, stroke it with a 428 crank, and run Ram IV top end on it. I've run a Ram IV top end on a 428 many years ago, and it was awesome.
Mike
Old 02-02-2016, 08:41 PM
1973T/A's Avatar
Mike
I have considered running a 428. My old man has a ra4 that's a blast, so it's certainly crossed my mind. I'll have to check my 400 blocks too see if any are 4 bolts.
Old 02-02-2016, 09:08 PM
Put Orig engine back in just build it right
Old 02-02-2016, 10:38 PM
weranc55's Avatar
weranc55 weranc55 is offline
I agree
Old 02-02-2016, 10:43 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
My 73 4-speed had the same linkage hanging in the same position. Someone unhooked it and just left it there. Weird thing was, it didn't have headers yet. Running Tri-Ys now.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 02-03-2016, 12:12 AM
1973T/A's Avatar
Well I've really gotten into the car. Little discouraged at what I've found.
Old 02-03-2016, 12:13 AM
1973T/A's Avatar
Old 02-03-2016, 12:14 AM
1973T/A's Avatar
Old 02-03-2016, 12:16 AM
1973T/A's Avatar
Old 02-03-2016, 12:20 AM
the 70 I have been helping with was like this, just pick an area as a project and get it done, area by area. a rotary could help. The lower 'air horn" area is available repop.
Good luck, and thanks for the pics!
PS, you are NOT alone!
Old 02-03-2016, 02:46 AM
1973T/A's Avatar
Like a friend keeps telling me it's only metal! You are right! There is probably worse ones out there too. Going to need LOTS of advice and knowledge on this project.
Old 02-03-2016, 01:12 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Thumbs up
I am working on my '70 as well. Mine will need a lot of outer sheet metal but structure is solid and rust free. I will subscribe as I will probably have alot of the same questions as you do.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 02-03-2016, 02:18 PM
weranc55's Avatar
Looks like a lot of work but the good thing is its a blue car with the original drivetrain.
Old 02-03-2016, 02:20 PM
1973T/A's Avatar
Reading your thread has given me hope!
Old 02-03-2016, 06:40 PM
x-bird2 x-bird2 is offline
pretty common areas to have to deal with. might as well figure on 2 quarters, the tail panel, wheelhouses, trunk extensions, trunk n floors. had to patch my lower cowl in the same area, but wasn't quite as bad. I have an NOS door support for pass side, pic n post down in the classifieds.
