Old 02-06-2016, 07:48 PM
gtobird's Avatar
gtobird gtobird is offline
Default Best intake gaskets to block cross over
I decided to block the cross over on my intake so it won't cook the paint off my intake. The car will never be run in cold weather anyway, so it won't matter if the choke doesn't function when cold outside.
I would like to just buy intake gaskets that will block the cross over rather than to do a homemade job. What do you recommend, if you've used the gaskets out there? Felpro and Mr Gasket make them. I think Edelbrock has them and some others as well. My heads and intake are all stock 1968 400 items. I just want it to work and seal well.
Please let me know which gaskets worked for you (mfg and part number).
OJ
Old 02-06-2016, 08:51 PM
ponyakr's Avatar
ponyakr ponyakr is offline
I always used the Mr. Gasket 502g, with the thin plates. Never burnt out any on my bracket racers.
http://www.summitracing.com/parts/mr...FRCGaQodjxsOag
I think some use the FP 1233's and add a thin plate, along with the solid insert, to keep from burning thru.
http://www.summitracing.com/parts/fe...FQ-PaQodaWwNsQ
I reckin you could just cut some plates out of thin stainless, which might last longer. Don't know what the best thickness would be, but there are lots of sizes available. There's a 6x12" .012 thick sheet on the WM site.
http://www.walmart.com/ip/38428305?w...981049&veh=sem
And here's a .028 thick sheet.
https://jet.com/product/detail/97c84...FQgGaQodYBoDrQ
Apparently a lot of hobby shops carry small pieces of stainless in different thicknesses.
http://www.hobbylinc.com/htm/k+s/k+s87181.htm
http://www.hobbylinc.com/htm/k+s/k+s87183.htm
http://www.hobbylinc.com/htm/k+s/k+s87185.htm
https://www.hobbytown.com/Shop/K-S27...t-Metal-4x10-/
"...I would like to just buy intake gaskets that will block the cross over rather than to do a homemade job..."
The homemade job, with stainless plates. may last longer.
Old 02-06-2016, 10:20 PM
rohrt rohrt is offline
I just buy a correct felpro gasket and open the exhaust crossover port about 1\8 so there is a lip. I then trim a SS putty knif to fit. I use a little RTV red.
Old 02-22-2016, 12:28 PM
1968GTO421's Avatar
All these are good recommendations especially the ones about a thin piece of stainless. Have used Mr G intakes with the crossover blocked and it burned through. The stainless pieces sound like a permanent solution (although on his Chevelle, my brother used cuttings from a beer can and they held-- LOL).
However way you go, do not forget to weld or safety wire the heat riser valve in the open position (or have it removed entirely). If you have headers, disregard this.
Old 02-22-2016, 09:28 PM
Ron Landis's Avatar
Thumbs up PSSTTT...
pack the crossover ports with balled up aluminum foil...keeps the majority of the most intense heat away from the paint you're trying to protect. Works for me...learned it from an early Hot Rod magazine that claimed it was good for @ 10 hp...I dunno.
Old 02-22-2016, 09:31 PM
form74's Avatar
form74 form74 is online now
I used those, over 10 years with no issues.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
