Old 02-07-2016, 10:34 AM
pontiacman63383 pontiacman63383 is offline
Question Carb confusion help
So im trying to Figure out what size carb I need. Motor is a 400 stroked to 461, 4x heads, old faithful cam with 1.65 rockers and edelbrock performer RPM intake. 9.8:1 CR. Now when I run my motor though a Carb calc. it shows I need a 624 cfm (this is with an assumed redline of 5500 and .85 VE) But when I search threads for similar size motors it seems like the 450+CI motors are getting recommend 800 CFM or higher carbs. So am I just missing something? Am I inputting the wrong numbers? Just want some help before I drop cash on a new carb. Thanks guys.
Old 02-07-2016, 10:44 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I would run a 800 on those heads if they`re not ported. They should be with that cam. If ported, run a 850, 4 corner idle.
Old 02-07-2016, 11:00 AM
STEELCITYFIREBIRD's Avatar
Get a vacuum secondary carb for street use, Most engines are over carbed but vacuum secondary type carbs are forgiving, whether its a qjet or holley. On these type big inch Pontiacs, I don't have any real world experience to give a # from experience. I don't think anyone can make a solid recommendation on cfm without more info.
Old 02-07-2016, 11:04 AM
74Grandville 74Grandville is offline
what type of carb are you leaning towards? factory Q-Jets were 750 and 800cfm.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 02-07-2016, 11:15 AM
leeklm's Avatar
leeklm leeklm is offline
Many opinions and preferences out there, but a properly built qjet is tough to beat for street use, and works well for occasional strip runs. As a general novice with the qjet and Holley, I find the qjet to be easier to reach good street manners. But then again it seems that my Holley ' s are always some old piece of crap someone else butchered up.
Sent from my SCH-I545 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 02-07-2016, 11:16 AM
ponyakr's Avatar
ponyakr ponyakr is offline
Why not just go with a WELL BUILT 800 Q-jet, and don't even give it another thought. They can be tuned to run great, as a daily driver, or run 10 sec ET's at the track. It's a no brainer. IMO--But then, opinions differ.
Old 02-07-2016, 11:27 AM
shaker455's Avatar
shaker455 shaker455 is offline
I would recommend an annular 850
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 02-07-2016, 11:35 AM
Tom Vaught's Avatar
Boost Engineer
X2 on the annular deal or even the good downleg booster.
Cliff R had a very nice running Holley 850 Double Pumper carb on his engine and there
were minimal mods to make it run as well as his $$$ Q-jets. The carb might use a bit more gas (but gas is cheap these days) and you can also use a lot better square bore manifolds without mods to them to make them work with the 850 carb.
You would be on your game with a properly built Shaker 455 850 DP Holley.
Tom V.
Old 02-07-2016, 01:27 PM
ponyakr's Avatar
So, there you have it. Some like vanilla--some like chocolate. Some like Q-jets--Some like Holley DP's--Some like street tuned Dominators--Some like Holley vac sec--Some like other brands of Holley type carbs--Some say FI is the only way to go nowadays. It's no different than a cam thread.
So, take your pick.
Old 02-07-2016, 01:41 PM
I don't have much experience with a carb so brand is not a big factor to me. I have no prob with a q-jet or holley. I had to do some research as I did not know the difference between annular and a downleg. I would prefer the annular. Im not worried about the fuel cost either as this will be a weekend fun car and already had 3.73 and a M22. So I don't expect good fuel mileage. everyone seems to agree about the 800-850 CFM range but the question I still have is why is the formula I see everywhere so far off? Is it a Pontiac thing?
Old 02-07-2016, 02:01 PM
Steve C. Steve C. is offline
Choosing A Carb Size. Yes, lots of opinions.
One of the most asked questions we receive at PRO-SYSTEMS is, how big will my carburetor be, how much will it flow? Most customers are expecting to hear big numbers.
http://www.pro-system.com/pjames011900.html
Old information here:
Old 02-07-2016, 02:04 PM
ponyakr's Avatar
Lots of guys like the Quick Fuel brand.
http://www.gtoforum.com/f178/opinion...tml#post624025
Here's some of their street carbs.
http://www.quickfueltechnology.com/carburetors/street/
Old 02-07-2016, 02:12 PM
shaker455's Avatar
We build Qjets here too.. no bias
Old 02-07-2016, 02:13 PM
shaker455's Avatar
I've found properly jetted & modified they do good on gas.
Old 02-07-2016, 05:07 PM
Tom Vaught's Avatar
Boost Engineer
I know for a fact that Pro Systems buys the same parts from Holley that I (and Shaker 455) buy so then it comes down to who knows more about how to tune a Holley carbed Pontiac Engine. Without a lot of research, the only two Pontiac names that come to mind were the carb Jim Hand bought from them and a carb used by a second guy.
Jim sent me the PS carb to evaluate and I found nothing in the carb that was anything special in the way of putting it together or the calibration.
The other gentleman actually tried several times to use the PS carb and actually had better luck with his well tuned BG carb.
I think his background with PONTIAC engines and carbs is limited.
Tom V.
Old 02-07-2016, 06:55 PM
ta man ta man is offline
Off topic..but who did the head work?
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 02-07-2016, 07:01 PM
Noting that Patrick James (Pro-Systems) formula to determine carb size is different than the common or in his opinion 'old' formula. A fwiw for interest.
Old 02-07-2016, 08:32 PM
heads are stock right now. Just cleaned, fluxed, and a valve job. Precision engines in Illinois did the heads and the block. Im thinking of having bier brothers here in ofallon port them.
Old 02-15-2016, 12:36 AM
tooski tooski is offline
Excuse me for revisiting this 'older' thread.
While there were many recommendations and info on which carb to use, the OP seemed to be interested in (as am I) as to why he would need an 800 cfm, or more, carb when the calculators he used shows he needs about 624 cfm.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 02-15-2016, 01:17 AM
Using what is now considered to be an outdated formula, 624 cfm.
Read the link Steve C posted above for a more modern and accurate take on carb sizing:http://www.pro-system.com/pjames011900.html
