Old 03-09-2016, 09:45 AM
dkpilot dkpilot is offline
Default Air cleaner vacuum hose
68 GTO 4 speed.
I am trying to get all the vacuum lines hooked up as original. I have everything correct for the thermostatic vacuum switch.
My question is, where does the air cleaner vacuum hose go? It was attached where the "yellow" hose from the switch is now going.
I do not see any "open" ports on the carb. The only available port is on the manifold just in front of the carb.
Old 03-09-2016, 10:23 PM
Verdoro 68's Avatar
Pretty sure that port on the manifold is where it goes but I could be wrong.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 03-09-2016, 11:07 PM
dataway's Avatar
dataway dataway is offline
If you have a 68 service manual, look at page 6B-2. View B, 4bbl carb ... shows the vacuum line coming up from a manifold fitting right behind the thermostat housing. About in the middle of the front runner that goes to the front two cylinders. It's a small port, not the larger one with the square fitting.
I can post a scan if needed.
Old 03-09-2016, 11:26 PM
dataway's Avatar
See pic in upper left.
Old 03-10-2016, 07:36 AM
Thanks so much. That's exactly what I need.
I have the restoration guide, but not a service manual.
Old 03-10-2016, 12:18 PM
dataway's Avatar
Just do me a favor and remember the answer, cause I'll forget it before it's time to put my engine back together
Old 03-10-2016, 07:00 PM
I printed the picture for my file. I can always send back to you if your memory fails.....
