Old 03-12-2016, 06:11 PM
MD79TA MD79TA is offline
Default 68gto turbo 400 question
I'm in process of getting everything hooked up on my 68 400/400 GTO. I have a question on how the kick down works on this year. Before I pulled motor and had new motor and tranny rebuilt it did not kick down at all . The only way was to manually shift to the lower gear. Only drove for about twenty miles. It has the hurst his/ her shifter but I think I am missing something . Thanks in advance any picture would be great.Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 03-12-2016, 06:32 PM
Verdoro 68's Avatar
There's a kickdown switch on the gas pedal - is that present and working?
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 03-12-2016, 07:04 PM
stevep's Avatar
stevep stevep is offline
Make sure that when you floor the gas pedal, it pushes the switch all the way down. There has to be 12 volts going to the switch and when the switch is pushed all the way, it should sent 12 volts to the connector on the side of the transmission.
Old 03-12-2016, 07:23 PM
Anyone has a picture of what it looks like? Not sure if it even there?
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 03-12-2016, 07:36 PM
Took picture under dash by pedal?
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 03-12-2016, 07:41 PM
One more
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 03-12-2016, 07:56 PM
marxjunk marxjunk is offline
thats the switch and the right pedal, switch could be bad..easy to test it works or it doesnt
check continuity slide it,it works or it doesnt its on and off..
you have another issue there..those purple wires are neutral safety..and they are out of the plastic connector from the console harness and they jumped it with the blue wire..it will start in any gear and thats bad or potentially bad
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 03-12-2016, 09:36 PM
Verdoro 68's Avatar
Looks like someone also put a piece of hose on the kickdown too presumably to get it to kick down earlier. I wonder if that was a band aid for the switch not working right.
Ken
'74 Ventura 350
'69 AMC Javelin SST
