Old 03-15-2016, 10:44 PM
MD79TA MD79TA is offline
Default Radiator core support
Here are two pictures. One is the kit Ames sent me. The other is a picture of the original mount flange with nut built in. Did they send me the correct kit or is this for other year? I thought I would get two bolts and bushing with no nuts since they are part of that mount? Any one have a diagram of how it goes together . For my 68 GTO. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 03-17-2016, 01:16 PM
Based on your photo, it looks like you may have ordered/were sent Ames S390 (64-67), whereas you would probably want S391 for 69-72 applications. The Ames catalog does not include a photo of S391 but what you have there is different from my original pieces. I've included a photo of my original pieces (the bushings are repos from OPGI). There's also a photo of assembly order, the mount flange goes inside and rests on the bottom of the frame rail. The rubber sandwiches the core support. If you clean the crud off of your mount flange, you should be able to reuse it. If you want new ones you would also have to order Ames S396.
Name:	Core mount 2.jpg
ID:	423790   Click image for larger version
Name:	Core mount 1.jpg
Old 03-17-2016, 04:31 PM
Sent all picture by email to Ames . They said that is the correct set for 68 so I will try to use. Still think that bolt is to short? Any one else use this kit? Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 03-17-2016, 06:01 PM
hakansan's Avatar
hakansan hakansan is offline
You got the correct mounts.
This kit include lower washer and locking washer if You dot use the old "nut" in Your Picture.
These "nuts" are sold by Ames as:
https://secure.amesperf.com/qilan/Se..._part_num=s396
Håkan
`70 GTO, 370 hp, 3:90, TH400.
Old 03-17-2016, 08:18 PM
Can you tell me the length of the old bolts? The bolts in new kit is 3 in long. Thanks Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 03-18-2016, 12:07 AM
3.5 inches not including the head.
Old 03-18-2016, 10:17 AM
hakansan's Avatar
Here is Ames S390:
https://secure.amesperf.com/qilan/De...A&web_access=Y
