T-5 ??
Can some one tell me if or if not this can be done. I have a junk yard close to me that has a t-5 out of a Firebird that I can buy for little of nothing. I have in my 73 GTO right now an M-22 rock crusher & like it a lot , but with 3:73 rear gears I get low low gas mileage. I would like to know ahead of time if & happen to get it will it be a direct fit. Can I just pull my 4 spd. out & just slide the T-5 in it's place? I know the 11" clutch disc is an 11" piece with fine spline, but does the T-5 have the same & will it bolt right up to my std. Pontiac bell housing. Or do I have to change a bunch of things. Also will I be able to use my std. linkage. DO I have to change it to a hyd. clutch & through bearing. ???
