Old 03-30-2016, 08:23 PM
Jason Rogers Jason Rogers is offline
Default Manual Steering box
I have a manual steering box 5679142, but I'm not sure it is for my 1967 Firebird 400. Anyone know?
Old 04-01-2016, 10:56 AM
ttt
Old 04-02-2016, 10:03 AM
silverbullet07 silverbullet07 is offline
that casting was used on many cars from 67 - 79 including yours. 67-69 had a date code on the little pad on the top to identify julian date and year.
Old 04-02-2016, 11:08 AM
So i think my box is original then. A1167 would be April 26th of 1967 i believe. My car is 06C which is 3rd week of June 67.
Old 04-02-2016, 01:50 PM
I would say it is.
Old 04-06-2016, 09:07 AM
How hard are they to rebuild? Mine is ridiculously sloppy. Kit?
Old 04-06-2016, 03:15 PM
jcruz's Avatar
jcruz jcruz is offline
I had a lot of play in my 69 manual box. I ended up just trying the adjusting screw on top of the box -- worked like a champ!
69 Firebird/TA clone
Old 04-29-2016, 03:26 PM
If I crank down on the screw the play goes away. I was thinking about just washing the insides out with gasoline and then pumping in lithium grease? I read somewhere that there are bearings packed in bearing grease. Is that different than the grease on the worm gears?
Old 04-30-2016, 09:25 AM
ttt
Old 04-30-2016, 04:53 PM
Anyone have pictures of how these should be restored/painted?
Old 04-30-2016, 05:30 PM
Here are photos of my restored power steering gearbox if it helps.
Name:	68Firebird400HO-1840 (Medium).jpg
ID:	427437   Click image for larger version
Name:	68Firebird400HO-1841 (Medium).jpg
ID:	427438   Click image for larger version
Name:	68Firebird400HO-1842 (Medium).jpg
ID:	427439   Click image for larger version
Name:	68Firebird400HO-1843 (Medium).jpg
Old 05-02-2016, 07:52 PM
Kurt S Kurt S is offline
I believe it's a special grease. Look in the Overhaul manual.
Info on steering boxes: http://www.camaros.org/suspen.shtml#steer
Kurt S
CRG - Camaro Research Group
Old 05-02-2016, 09:50 PM
I found a hotrod article that said 85w-140 and wheel bearing grease for the bearings. Bought a rebuild kit from www.midweststeering.com. RK550.
Old 05-08-2016, 09:19 PM
I am almost done rebuilding the box, but I can't get the brass sleeve out. Any hints?
Old 05-09-2016, 07:45 PM
Got it out. I was able to pound it straight into the box.
The Pitman arm has a greasable joint. Is that replaceable? There seems to have been a rubber seal around it which is 99% gone. If you can replace it, should I do the whole thing or just find a new seal?
Is the power steering box cover aluminum on yours? I think my manual is cast iron so it would be the same color as the case.
Why is the spline copper colored?
Old 05-11-2016, 03:01 PM
What's the secret to loading the ball bearings. They fall out the end. Grr.
Old 05-12-2016, 09:06 AM
Anyone?
Old 05-22-2016, 01:45 PM
Finally figured it out.
I mixed lithium grease and gear oil in the case and it is leaking out of the adjustor end. Are you supposed to put sealer on the threads or is my "slurry" too runny?
Anyone know where to get the grease boot for the pitman arm?
Do I have it painted correctly?
ID:	428957   Click image for larger version
ID:	428958   Click image for larger version
Old 05-23-2016, 09:11 PM
Box paint looks ok, I think the shaft should be a more "silvery" color as it will be steel as opposed to cast iron gray. I dont know what color but it should not be the same color as the box. As for the pitman arm, its just a cheap foam type rubber seal. You get one when buying a new arm, but its just a cheap seal. As long as it keeps the dirt out. Think of it as a 1/4" thick black foam washer.
Bill Nye.
Old 05-24-2016, 09:04 AM
I think Ames has the little felt type washer for the pitman arm.
