is engine assembly lube the same as cam break in lube?
11.940@114.21 / 1.843 60'/ 3980 lbs 1964 corvette roadster 1968 corvette roadster 1962 corvette "equal rights, not equal things" if you want to know the future, read "atlas shrugged" I dont race a 4spd because it is easy, I race a 4spd because it is hard. ![]() |
What type of cam?
torco mpz cam lube
Brad penn straight 30
Factory hydraulic chevy L-79 in a 327. just didn't know if there was "special" cam break in lube on initial startup, or will "normal" assembly lube work?
Normal assembly lube should be fine. Fact is nothing is going to remain in place with a little heat and oil pressure.
Flat tappet cam lube needs to have moly in it.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
