I'm sure this has been discussed, but I can't find it. Can I put my '69 RAIII (4 speed) engine in with the stock RA exhaust manifolds and starter already installed? It'd sure be easier to put them on on the stand. I know I'd need to disconnect the engine harness at the bulkhead connector and put it on the engine (it has the factory harness tube on the motor mount).
I took them off in the car before pulling the engine -- what a pain! The frame is painted, so I don't want to have to move the engine around a lot. It has power brakes, so I know that makes it tighter. I won't put the distributor in until the engine's in place. The transmission is out. Thanks for advice!
Lee Peterson ------------- "I didn't expect a kind of Spanish Inquisition...!" '69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car. |
Put engine in without exhaust manifolds and starter.
Rich Johns Owner/Operator of Pure Stock Auto Restorations Inc. www.purestockauto.com 1969 GTO Judge Ram Air IV M21 4 speed 3:90 1970 GTO Judge Ram Air III M21 4 speed 3:90 Oshawa Built 1970 GSX Stage 1 M21 4 Speed 3.64 # 67 of 678 Original Paint 1970 GSX Stage 1 Auto 3.64 # 603 of 678 [email protected] mph 2011 Buick GS Nats Pure Stock, [email protected] mph PSMCDR 2011 1970 GS Stage 1 Convertible Auto 3:64 [email protected] mph PSMCDR 2009 1970 GS 455 M21 4 Speed 3.42 1987 GN Astro Roof |
Agree. Manifolds drop right in after the engine is installed, just put some towels on the frame to temporarily protect it. You'd have to drop the starter to wire it up to the harness anyways.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
I put my RA manifolds on and then installed the engine. No power brakes. I did not have any problems. Dropped right in. Don't know about the starter as I use a mini starter and its not hard to put on after the engine is in. I used cardboard on the frame just in case.
When I put the engine back in my 73 GTO I had to take the manifolds off as there wasn't enough room to install them on the engine into the car. I had the starter on but I run a mini starter on my engine.
I took my starter off.
Cuz68 |
You can do it with both on but the studs need to be taken out of the manifolds.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
Thank you all for the help. I think I'll try with it all together -- sure not fond of rolling around underneath.
Thought I'd reply with how it went putting the engine in with starter and manifolds on.
This is a stock RA III 4 speed with factory manifolds and starter. I'd highly recommend it. I took the engine harness off at the bulkhead connector, installed the tube with the harness and battery cable in it on the left motor mount, installed the starter with the rear brace, and the manifolds (without studs). I also installed the clutch linkage pivot with the engine out. It went in very easily -- didn't have to fight it at all. It's close on the brake booster, but not bad. I think it'd be a mistake to have the distributor installed, although you could probably get by as long as the cap isn't on. I didn't want to take a chance. I really liked not having to lay on my back fighting to get the starter and manifolds on -- really made my day when it slipped right in.
when I do them the distributor is in as well as the manifolds and starter
just have to leave the studs off the manifolds. |
I see where AG said to remove the studs when installing the engine. I think it would have gone in for me if I would have taken the studs out of the manifolds. It was the studs that were keeping me from installing the engine with the manifolds on the engine. I'll try that next time as putting the manifolds on in the car is a bit of a pain.
