Prev Previous Post   Next Post Next
Old 04-11-2016, 09:06 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Extended crank time
After sitting for 1-2 weeks without starting my car takes quite a bit of time to start. It takes about 45-60 seconds of cranking with a few seconds break every 10 seconds or so. If I start it one day then the next it fires immediately.
I have a rebuilt 400 with a lunati 276/284 hft cam and edelbrock dual quad intake with matching dual Carter 400cfm carbs. Choke only on the primary. 1/2" fuel line from tank to RobbMc 550 mechanical pump and 1/2" fuel line from pump up to the carbs where it Tees off to 2- 3/8" lines
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
