The Pure Stock Muscle Car Drag Race (PSMCDR) organization is announcing the inclusion of select 1975 to 1979 Pontiacs allowed to participate in the best Pure Stock Drag Race in America. Due to many folks asking if they could participate and race their 75 79 performance Pontiacs over the years, we have decided to allow performance focused Pontiacs to the event (this year is September 15, 16, & 17).
The following list of cars may participate: Year Model Engine Rated Horsepower 1975-1976 LeMans/GP 400/455 185/200 1977 LeMans/GP 400 185 1977 Can Am 400 200 1975-1979 Formula 400/455 185-220 403 when equipped (78-79) 1975-1979 Trans Am 400/455 185-220 403 when equipped (78-79) Please refer to the PSMCDR web site for the rules, but in a nut shell, you can run a 2-1/2 mandrel bent exhaust system with the muffler(s) in their factory position without catalytic convertors; any gear ratio; stock or close to stock cam (16 vacuum at 1000 rpm); radial tires in 60 series max; stock torque converters (12 TH350/13 TH400); factory transmissions, interiors, bodies, paint color(s), wheels, etc.. Engines can run 1.5 points higher compression (7.6=9.1 max/8.0=9.5 max/8.2=9.7 max); stock or very close to stock cam specs (16 vacuum at 1000 rpm); factory carb (and type for year); heads/intake/exhaust unmodified; max .070 overbore/ .015 stroke increase (from previous machine work) allowed; all belts to operate power steering and alternator (A/C belt can be removed). We will P&G (displacement), Whistle (compression), and check vacuum on cars that run 13.50 or quicker to inure compliance to the rules. |
Why do they get to take off the cat cons. You can't have them as a street car if the cat con is off, by law. If every one else has to be by the rules why do the late models get to change the rules to run.
In my area, anything over 25 years old is emissions exempt. So I have not been running cats on any old Pontiacs for the last 14 years.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
I wouldn't want to live where they're that anal about antique emissions equipment. I'd have to move .
Steve F. |
Dennis |
(not having read the latest rules)
What are the rules for the older cars, can they use any exhaust on them?
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
Dennis |
For additional info, not all f-bodies had transverse mufflers. For example, my 79 TA's originally came with duals behind a single cat. And looking at the 78 Pontiac service manual, some 78 Firebirds/TA's with 400 engine had the same dual exhaust setup as my 79's.
Steve F. |
Grand73Am, Yes that is what we will allow for the '78-'79 F-bodies to run, which gives them a slight advantage, but ever so slight.
Dennis |
