Old 04-17-2016, 02:46 PM
Check6 Check6 is offline
Default What amount of voltage should be at the battery terminals when car is running?
Just replaced my battery on my 66 GTO 389 4 speed. What voltage should I be reading at the terminals with the car running? Also how do I check the voltage regulator and alternator for correct voltage output?
Thanks,
Fred
Old 04-17-2016, 03:05 PM
tekheavy's Avatar
tekheavy tekheavy is offline
I'm sure you'll get a lot of difference answers, but you should be in the neighborhood of around 13.8 volts with the car running. If you're down in the low 12's or nearing 15 volts or higher, you probably have alternator or regulator issues.
Old 04-17-2016, 03:27 PM
Mine is reading over 15 volts with the engine running. How can I check the regulator and alternater. Is the voltage regulator built into the alternator?
Thanks,
Fred
Old 04-17-2016, 04:15 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Thanks,
Fred
On a stock 66 the voltage regulator (Delco-Remy) is mounted on the firewall.
Old 04-17-2016, 04:21 PM
OK guys thanks for the input. I disconnected the leads going into the voltage regulator and plugged them back in moving them around. Now I'm getting 13.5 volts with the car running and the headlights and blower motor on. Guess I had a bad connection at the voltage regulator.
Thanks,
Fred
Old 04-17-2016, 04:27 PM
Longs's Avatar
Longs Longs is offline
If I recall correctly, the external regulator should limit the voltage to about 14.5 volts. That's one of the reasons that if the battery goes bad, the charging system can't "force" a charge into the battery - the voltage limit.
Old 04-17-2016, 07:54 PM
GT182's Avatar
GT182 GT182 is offline
Check6, clean the trerminals and the plug side then use a bit of dielectric grease on the terminals so the don't corrode.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
