Old 04-25-2016, 10:32 PM
Tommo99 Tommo99 is offline
Default Heater tubes
Has anyone got a good diagram that shows where all the small hoses go for the heater etc up under the dash, there are 3 or 4 rubber hoses that have a different coloured tracer on the hose approx 5/16 or 1/4 in diameter they run from the heater assembly under the dash and some go through the firewall via rubber grommet.
Old 04-27-2016, 05:42 PM
pfilean's Avatar
pfilean pfilean is offline
What year? A/C or no A/C? It is usually shown on shop heater A/C manual.
Old 04-27-2016, 05:51 PM
Stuart's Avatar
Stuart Stuart is offline
Also, depending on the year of your car there may have been two different types of heaters available (Direct-Aire or Circ-L-Aire.)
Old 05-02-2016, 02:07 AM
59 Catalina standard heater I think no air con, I can post pictures if that helps cheers
Old 05-02-2016, 09:25 AM
Stuart's Avatar
There are a couple pictures over on the pontiacsafari.com page that may be of help:
http://www.pontiacsafari.com/MPC/Pages/page_0496.jpg
http://www.pontiacsafari.com/MPC/Pages/page_0497.jpg
However, they don't appear to show the vacuum line connections. You'll probably have to wait for someone who has a 1959 HVAC shop manual to post pictures.
Old 05-02-2016, 11:54 AM
pfilean's Avatar
Pictures Stuart sent make the control look very much like the 61 Circ-L-Aire heater. This may help. But good luck if the vacuum control leaks . They are near impossible to get to seal up when they get old.
Old 05-03-2016, 03:12 AM
Default Heater hoses
Awesome thanks
