Set a personal best on sat at the Rock, Track is still green cause its new, but once a little sun came out later on, and they dragged it and sprayed it came around briefly, and I made 4 great passes with 60fts all 1.42-1.43, That's still leaving at only 2500 on the FB,The weather was cool, 58 degrees? Hum was around 40%, But there was a terrible headwind , gusting over 20+.
I was very pleased with it, Shifting at about 6200, thru the traps about 6550 and I think it shows great promise that there is plenty left in it!
Great job!
Awesome!
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
Would you quit it. I keep trying to catch you, but you keep going faster.
Less said,,,,,,,, Less mended. |
Awesome..getting closer!
Ernie,
When's your next trip to track? W/ Andy? Hope Chris can go soon also! Tres Poncho's ![]()
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
great job Darby! that thing is hauling a--!
Gene Kinch 1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116 1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108 1971 GTO 400,t400 3.23 10 bolt all original 14.41@96 1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85 1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction) 1979 TA, 400/ 4 speed all original needs restoration. 1999 Trans Am LS1 |
Darby-
Did you make any changes over the winter? |
Thanks Guys!
Tininjun, sorry cant stop now ![]() John, I changed my emulsion package in my dominator, Went from the 2 like a stock holley location and went to 3 with alot smaller holes, but still the same in area as my 2 were. I also went to a msd dist with one spring off the advance trying 30 total instead of the 26-27 i ran on the dyno and all of last year. Im guessing u factor out the wind i picked up a solid tenth maybe more. I'm still on old tires too.
Awesome job. Keep tuning.
Nice job Darby! Been wondering what you were up to. Didn't doubt you would be posting up a new best. Prob been asked before, but what converter you running?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. Last edited by torqjunki; 05-02-2016 at 11:51 AM. Reason: Fat finger |
![]() Quote:
Thanks! I'm always up to something ![]()
Good job!
Nice job Darby. Jake & I were both there. You were busy talking to the woman when we came by the car. It sounded like you were on the brake??
Brian
Boobs & bacon ![]() |
I'm planning in 2 weeks testing a new intake ported by a fellow board member...I know Andy went through a rather extensive rebuild and is getting really close...Chris is pretty well ready too....I know us 3 aren't your typical hardcore dragracers...but we live and die by the timeslip too!
That was u guys? Dammit ,lol... No brake, just a two step wired so i can foot brake it.
Congrats Darby, I predict we'll see 9's in the near future!!!!!
Nice run. Where do you think you have more, the 60 foot?
60ft, and the whole run, the wind was definitely holding me back up top, a friend was down 2 mph in his low 10 nova. I didn't even get to try my Wilson spacer etc.
Great improvement and as you posted still more there. The 60 ft times are coming around for you.
Keep up the good work. Beginning of the season! Tom V.
