Old 05-16-2016, 12:11 AM
TransAmRIP's Avatar
TransAmRIP TransAmRIP is offline
Default 1975 Trans Am Restoration
Here I go again! New project 1975 Trans Am 400 4 speed (numbers matching) Sterling Silver standard interior (Black) 46xxx original miles 99.5% rust free last on the road in 1996. The restoration officially starts Monday the 16th May, 2016.
Stay tuned!!!
ID:	428495   Click image for larger version
ID:	428496   Click image for larger version
ID:	428498   Click image for larger version
ID:	428499   Click image for larger version
Old 05-16-2016, 12:14 AM
TransAmRIP's Avatar
More teasers....
ID:	428504   Click image for larger version
ID:	428505   Click image for larger version
ID:	428506   Click image for larger version
ID:	428507   Click image for larger version
Old 05-16-2016, 12:19 AM
TransAmRIP's Avatar
Last but not least.....
ID:	428509   Click image for larger version
ID:	428510   Click image for larger version
ID:	428511   Click image for larger version
ID:	428512   Click image for larger version
Old 05-16-2016, 01:08 AM
Metal looks good , but the interior is definitely in need of some TLC. Hope it all goes good.
Old 05-16-2016, 07:30 AM
77 Canamman's Avatar
Looks like a great start. Let me know on those parts....
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 05-19-2016, 11:36 AM
TransAmRIP's Avatar
Will be ordering all new interior,
Old 05-19-2016, 11:52 AM
TransAmRIP's Avatar
Default Update #1
Lifted car so I could cut out and remove old exhaust. Removed rear sway bar. Pulled engine and transmission (pressure washed both). Started cleaning the fire wall and tunnel area. Looks really good once cleaned up. I will just clean the whole bottom of the car and bring back the original look like it left the factory with. Looks like no painting the bottom will be required like I had to on my 74.
ID:	428706   Click image for larger version
Old 05-25-2016, 08:55 AM
blue71ta's Avatar
blue71ta blue71ta is offline
Congrats on the purchase. Looks like you have a great foundation to work with.
Old 05-25-2016, 04:24 PM
TransAmRIP's Avatar
Hey Thanks, It should be a good project.
Old 05-26-2016, 11:44 AM
TransAmRIP's Avatar
Pressure washed the underside. Then began to hand scrub it with scotch bright pad and cleaner. You can see before and pictures (what a difference). Continue to clean rest of underside then move on the sub frame and rear end restoration. Nice shot of the air shock someone had on the car.
Bub
ID:	429303   Click image for larger version
ID:	429304   Click image for larger version
ID:	429305   Click image for larger version
ID:	429306   Click image for larger version
Old 05-27-2016, 01:26 PM
TransAmRIP's Avatar
Pressure washed rear end and made sure I caught the different paint markings.
Couple of questions; what color should the rear leaf springs and front mounting plates be? The pictures show them to be steal look? The axle tubes are steal and the center chunk is cast color?
Thanks Bub
ID:	429374   Click image for larger version
ID:	429375   Click image for larger version
ID:	429376   Click image for larger version
ID:	429377   Click image for larger version
Old 05-29-2016, 07:09 AM
Tonyqt's Avatar
Tonyqt Tonyqt is offline
Looking forward to the pictures of the progress on the car. It looks like a real solid starting point.
Old 05-29-2016, 11:52 AM
TransAmRIP's Avatar
This car is very clean and straight and it shouldn't take too long to complete it.
Old 05-31-2016, 05:53 PM
TransAmRIP's Avatar
Today I used a wire wheel on the rear diff. and taped off the letter G on bottom of the center housing and also taped off on the letter G on the top side. The bottom G was painted in Orange and the top G was painted in Blue. Also found some Blue markings on opposite ends of the axle tubes. Also found a Green dot in the middle of the tubes.
Looks like I will just spray some satin clear on the center housing since the wire wheel brought back the cast iron color to perfection. I'll paint the tubes with a steal colored paint.
I did try some EVAPO-RUST (njsteve method) on the rear diff cover and on the leaf spring plates. What a difference, it didn't even touch the green paint that was on the cover. Nice stuff saves a lot of time...
Bub
ID:	429594   Click image for larger version
ID:	429595   Click image for larger version
ID:	429596   Click image for larger version
ID:	429598   Click image for larger version
Old 05-31-2016, 09:47 PM
ladytata's Avatar
ladytata ladytata is offline
http://www.ecsautomotive.com/rpm.php?rpmlnk=main I've used this stuff, works pretty good.
Old 06-01-2016, 12:35 AM
TransAmRIP's Avatar
Hey thanks I'll have to try it out.
Old 06-04-2016, 02:29 PM
TransAmRIP's Avatar
Been using the EVAPO-RUST on anything and everything with rust associated with it. Talk about save time with this stuff. Did drive shaft, leaf spring axle mount plates and front leaf spring mount plates. Primed and painted the plates and left the drive shaft bare for right now. Painted the axle tubes and also added the blue inspection marks. Not sure why the last few pictures are rotated?
ID:	429878   Click image for larger version
ID:	429879   Click image for larger version
ID:	429881   Click image for larger version
ID:	429882   Click image for larger version
Old 06-04-2016, 02:32 PM
TransAmRIP's Avatar
Drive shaft after sitting overnight. Didn't even remove the yellow stripes.
ID:	429884   Click image for larger version
ID:	429885   Click image for larger version
ID:	429886   Click image for larger version
ID:	429887   Click image for larger version
Old 06-08-2016, 06:49 PM
TransAmRIP's Avatar
Finishing up on the rear end. Added the orange G and the yellow and white marks. Have a question about the color of the leaf springs. After I soaked them the evapo-rust and cleaned them up the color appears to be a dark gray. Is this the correct color for the 75 leaf springs? Hope someone will chime in on it. I thought they would of been steal shade.
Bub
ID:	430270   Click image for larger version
ID:	430271   Click image for larger version
ID:	430272   Click image for larger version
ID:	430273   Click image for larger version
Old 06-08-2016, 10:03 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default Leaf springs
I believe they were left natural by Pontiac but I always re-spray these in cast iron gray which I think looks very nice. I never cared for them when some guys paint them black. Keep up the nice work!
1970 T/A
