Old 05-21-2016, 01:36 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Default How to identify a Ram Air carb?
7028273 or 7029273
I know people like to keep this close to the chest but how can you tell the real from the fake?
Take the eBay item below, I am assuming not real by the price so far but I don't know. What am I looking for?
Look at this on eBay http://www.ebay.com/itm/291767862934
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 05-21-2016, 01:48 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
I want to know as well. It says in the ebay "Carburetor is a reproduction or re-stamped unit".
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 05-21-2016, 01:56 PM
GOAT WHORE's Avatar
Yes, I see that now that you pointed it out. I really just skimmed over the add as there are quite a few that I see. Anyway can still use that carb as an example.
Old 05-21-2016, 02:06 PM
Scott Thelander's Avatar
Default and
he is selling a 442 W-31 carb.....
hmmmmmmm.... fairly sure they never made a 442 W-31 ....I thought the 31's were Cutlass's .....
and different numbers........
and the font looks like the early stamping..not the fatter font I am used to seeing on the 2nd gen Qjets..
but ... my .02 worth .........
Scott
Old 05-21-2016, 02:59 PM
Kenth's Avatar
Kenth Kenth is offline
That carb started itīs life as a Buick unit.
Now itīs a destroyed restamped fake Q-jet. Total fraud!
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-21-2016, 03:02 PM
GOAT WHORE's Avatar
So what do we look for?
Old 05-21-2016, 04:19 PM
GOAT WHORE's Avatar
So it seams like a lot of the fakes start off life as a Buick carb, why is that?
Old 05-21-2016, 04:27 PM
marxjunk marxjunk is offline
ram air carbs have provisions for a rubber boot around the accelerator-pump...real clue there for sure...first thin to look for..
Pontiac uses it's own very unique bolt on arm too...base plates are something to look at
If it's so cheap it's too good to be true....it's too good to be true..
Search these forums there's 100s of images of real carbs save them on your computer and study them..it doesn't take much to figure it out...
There at least 3 fonts on Pontiac carbs..know which is right for the date is important to conclude real or fake..all the stuff the forgers do, they haven't got the stamps figured out yet..and that's why people with real carbs are picky about showing pics...
There's known dates for extremelly rare carbs because they where batch stamped..
I wouldn't be in a hurry, you can use any old carb and put the correct one on when you actually find one...
Greg, you probably need a 7028273 gm used them up on ram3s before they used the other..
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 05-21-2016, 04:32 PM
GOAT WHORE's Avatar
Thankx Marx (ya like that?) for the info that's what I am looking for. Already screen shot all the picks from what I believe is a real carb that sold on eBay for $3500. This is it, does it look legit?
Look at this on eBay http://www.ebay.com/itm/121964640176
Old 05-21-2016, 04:39 PM
GOAT WHORE's Avatar
Here are a few shots
ID:	428862   Click image for larger version
ID:	428863   Click image for larger version
ID:	428864   Click image for larger version
ID:	428865   Click image for larger version
Old 05-21-2016, 04:43 PM
Looks like it's right...there's a number stamped on the bowl..it's on the bottom of the fuel inlet..it's important..no one ever restsamps it
The other thing no one gets it the pick code..on that carb it's XX..the other is XB and others...they don't get that right either
The base has a casting number it's important too..
It could have a wrong base but right bowl..it's happened..
Pay attention to the font...it varies..and be patient
Mark..
The Goat whisperer
Old 05-21-2016, 08:07 PM
A Schab A Schab is offline
Correct me if I'm wrong but didn't that carb start life as an auto carb ? (Plugged front vacuum port). Shouldn't the primary blades also be drilled ?
Old 05-22-2016, 06:25 AM
Kenth's Avatar
No 1969 RamAir Q-jets uses the vacuum port on throttle plate, passenger side, for timing retard.
Also, the throttle plate is made by Carter. Carter never made ANY parts for a RamAir Q-jet.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 05-22-2016, 06:37 AM
Kenth's Avatar
Buick unit with Chevy throttle plate......
http://www.ebay.com/itm/1969-Pontiac...3D121964640176
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 05-22-2016, 05:54 PM
carbking's Avatar
carbking carbking is offline
Agree - I have custody of the Carter drawings. Carter castings on an alleged RA carb is a dead give-a-way that it isn't.
Jon.
Old 05-22-2016, 06:38 PM
tom s tom s is offline
Jon,,is the AP boot avail by itself?Tom
Old 05-23-2016, 03:35 PM
judger69's Avatar
judger69 judger69 is offline
I sent this ebay seller a question about the base plate casting numbers and side vacuum port on his $3500 RA3 carb. Strange, no response. But it sold 3 days later. It really is buyer beware and educate yourself.
If no one has already PM'd you, I have a lot of pictures of original 8273 carbs and what to look for. Drop me a PM.
Prefer to do it via PM and not post here so the numbers don't get out to the restampers.
Old 05-23-2016, 06:56 PM
carbking's Avatar
Tom - we don't sell any kit components separately, don't know if anyone else does.
Jon.
Old 05-24-2016, 11:56 PM
GOAT WHORE's Avatar
Judger69, thanks a ton for going out of your way to email me all the photos and info!
If anyone else is willing to email pictures or information to me it would be much appreciated and kept confidential.
Old 10-15-2016, 04:42 PM
dannla dannla is offline
Its sad that those of us looking to protect ourselves from getting scammed can't find the info to become informed buyers. I'm looking for a correct carb for my '70 Judge, but no one is willing to educate us! I understand the information could also be used for other to re-stamp and make frauds, but isn't that already being done? Knowledgeable folks are easily picking current frauds off E-bay, but the rest of us are screwed. I wont pull the trigger on a $3000 +/- carb (a CRAZY amount of money for a CARB) until I can be confident I am not being scammed! I was a police officer for 23 years. I'm not looking to screw someone, I'm looking to protect myself from being screwed. This is very frustrating!
