Old 05-24-2016, 09:18 AM
gtobird's Avatar
gtobird gtobird is offline
Default Bronze distributor gear?
I'm running the old GM points type distributor (68 400 engine). Just doing final setup for the test run / engine break in on my engine rebuild. I noticed the distributor gear teeth are a bit worn. Good enough for a test run on the engine test stand, but something I would like to fix before I do the final engine install. My goal was for an all original engine, so I have no intentions of going to HEI, nor going to a roller lifter cam. Engine is built to 400HO specs with the 068 cam and flat tappet lifters. Again, like the originals
So, what kind of gear should I replace the distributor gear with? Bronze or ???? I've heard you are only supposed to use the bronze gear with a billet roller lifter cam for Chevys (depending on the manufacturer). Not sure what is correct on a Pontiac. Using a Melling 54D oil pump (high flow) with normal oil pressure, not high pressure. I can't remember what the cam is made of, but it's nothing special in terms of material. Just an 068 grind. Bought it so long ago I can't remember anything more than that.
OJ
Old 05-24-2016, 11:18 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Do not use a bronze gear. Its for racing w/roller cams only and they still do a poor job at that. Use a stock steel gear.
Old 05-24-2016, 10:55 PM
Bet Winner's Avatar
Bet Winner Bet Winner is offline
If you ever get down to the bare block, I believe you can use a drilled oil galley plug that will squirt oil on the distributor gear. H-O Racing used to sell a set with a drilled plug at that location.
My Wife: "I thought I married a sophisticated business man, but what I actually got was a redneck fisherman with muscle cars."
Some people know all of their rights, but none of their obligations.
