I'm going to install a solid flat tappet cam. It will probably be a few weeks from the time I install it until I can fire it up for break-in.
What should I use on the lobes and lifters that won't run off in a few weeks time? The 'red' comp lube is kinda runny. How about a 'moly' grease? I will also be using Brad Penn 30w break-in oil,with zinc. |
I put on some of the green Sealed Power assembly lube about three weeks ago ... the upside of the lobes are now actually dry. Not just without a layer of lube... they are visibly dry.
Granted this is not cam lube .... I have some CC lube now, and some of that ultra high pressure grease too ...forget what it's called .... something like CM-3. Might try that. My engine will be probably sitting for a year before startup. |
Red line assy lube!
Moly grease, TSC has it for about $4 a tube......Cliff
Moroso makes moly paste in a tube, also.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
Cliff ... that's what I was thinking ... why can't I just use plain old, thick moly grease ... I know for a fact that would still be there in a year.
Been using it for decades, ZERO issues with it going anyplace no matter how long they sit before being fired up......Cliff
http://www.tractorsupply.com/tsc/pro...4-oz-cartridge
Thanks Cliff ... you made up my mind for me .... and I think I have a tube of that right on my tractor parts shelf.
Surely a good high pressure moly grease is as good for the first 2 minutes of running as any other fancy lube. After that, it's all about the oil anyway. And yep, I have no doubt that stuff would still be there a year later. |
I have a tube of moly grease assy lube,sta-lube brand I think.
CMD #3
Yep... that's the stuff, I have a tube of that I just bought .... it's pretty thick.
