Old 05-30-2016, 04:05 PM
tspring1 tspring1 is offline
Default 66 lemans repop bumpers
I purchased a front and rear bumper from Tamraz last week. The rear bumper looked good and fit well. I went to put my brackets on the front bumper and the holes for the drivers side are 1 inch to far apart, I measured the the 2 braces and there is a 1 inch difference in space between the holes. Is this difference normal.
Old 05-30-2016, 06:00 PM
Jeff Hamlin's Avatar
The braces are 2 part so to be clear are the discrepancies with the main frame rail brace bolts or between the main and outer/side support brace. The braces should be stamped/punched the same left and right/top to bottom spacing.
Old 05-30-2016, 08:15 PM
It would be the 2 vertical bolts. The driver side brace holes measures 1 inch shorter than the passenger side. If some one can measure the distance between the centers of the bolts on the passenger and drivers side on their bumpers. I want to make sure my braces are correct before I call Tamraz. I would hate to drill a hole in my new bumper to make my brace fit
Old 05-31-2016, 04:59 PM
Can anybody get a measurement for me. It would be greatly appreciated.
Old 05-31-2016, 07:21 PM
Exclamation
As indicated there is NO variance in bolt hole spacing left bracket Vs right.
If yours are that far off then something clearly is amiss.
The bumper & brackets on my '66 are oem. I laid out approx center lines off car to give you an idea of hole spacing (+- 1/8") and transposed my measurements onto this stock bumper image, as you can see they are equal. I have 7.75" top to bottom & 37.75" left to right.
This would apply to '67 as well. Maybe one of the brackets is slightly bent?
Hope it helps.
Old 05-31-2016, 09:02 PM
The 2 brackets with the vertical bolt holes should be mirror images of each other and mine are different from each other. My old bumper is pretty bent up but I think someone bent in the bumper to make the holes line up on the drivers side. Unfortunately the parts houses on sell both sides and not individual sides. I will need to find some one that will sell me the driver side bracket. Thanks for the help
Old 05-31-2016, 09:46 PM
abefromen's Avatar
abefromen abefromen is offline
I have extra brackets. Known good brackets not bent junk.
Old 06-01-2016, 07:51 PM
abefromen's Avatar
ID:	429690   Click image for larger version
ID:	429691   Click image for larger version
