Old 06-09-2016, 07:44 PM
ricks63 ricks63 is offline
Default 69 428 HO ENGINE XG CODE
I have a 69 428 HO block, crank, heads, intake, XG code with the four bolt mains. Block has been tanked and bored to 28", heads have not been touched, also have the crank and intake, possibly some of the other parts. Thanks 1300 plus shipping.
Old 06-10-2016, 07:35 PM
ChiefPonch ChiefPonch is offline
Where are you located?
Old 06-10-2016, 09:09 PM
Located right at Ontario/Grand Portage MN., I can probably get it to Duluth MN if needed. thanks
Old 06-17-2016, 12:08 PM
Any pics? How does it look in terms of external pitting etc? Not sure what you mean when you say bored to 28"?
Old 06-17-2016, 07:03 PM
I can get some pics i don't believe there is pitting on outside of block, it's bored to 28" so you can properly fit your pistons at 30" machine shop i use won't bore it to 30" without having the pistons for it. Thanks
Old 06-20-2016, 11:01 AM
61-63 61-63 is offline
He means .028 over I think so it cam be honed to whatever the pistons require.
Old 06-20-2016, 07:27 PM
Yes correct at 28" to properly fit pistons at 30'' will post some pics soon. Thanks
