511ci CV-1 build
Finally made it to the dyno last night. It's been a long road. This build started as a small upgrade from my 725hp ehead stock block engine but it kind of morphed into something more. On a shoestring budget, Calvin Hill was put to the test and he came through big time. I want to thank Calvin for all his effort and patience. I'd like to thank Jim from Roland racing for the lending me a intake, Tim Russo (FT LB) for lending me his headers, Mike Leech for the use of the carb, Mark @ Luhn performance for the awesome oil pump, Jimmy Lopez from JLO competition engines for tuning, and Troy from THP for the dyno session. Also all my friends for their help and support.
Here is the build ia2 block 4.375 bore Scat forged crank 4.250 stroke Aluminum rods Ross Pistons CV-1 heads Std. Cam tunnel In. .450 Ex. .440 Std. Lifter bore 14.5:1 compression 7.6 in of vacuum Everything but the Pistons, rods, lifters, and valves were used or borrowed. The thing was singing on the dyno. We pulled it seven times and made big gains on every pull except one. We only adjusted timing and changed carbs twice. Didn't get any video because the storage on my phone was full. Very first pull it made 898hp @ 6500 733tq @ 6300 Last pull 999hp @ 7600 736tq @ 6300 We could have kept going but it was late and we were all very satisfied. |
Congrats
Tom, congrats to you and Calvin!! It's been a long road but the results speak for themselves. Can't wait to see the GTO back on the track.
-Kevin
1972 Firebird 462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet 3925 race weight Best of 12.88 @ 105 so far |
Is that going the 66-67 (?) car in your avatar?
Should be a cool combo. How fast did you go with the previous engine? |
Thanks Kevin! |
Thanks, Tom |
Tom congrats! Hope you have a great time racing it!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.82@159.91 in Joliet May 2024 ….157.56 MPH in Gainesville in March ‘23 |
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Awesome build. Made great power. What's the cam at .050?
Thank you!
Thank you. I forgot but I will check and let you know
Nice build, will you have the car out this year? How high did you pull it to? What intake?
Thanks. I'm hoping to have it out later this year. We pulled it to 7800rpm.
You will have a lot of fun with that engine. Congrats on the dyno number and I am sure the car will be very happy with the additional 270+ horsepower.
Tom Vaught
Thank you. We'll be taking baby steps and and figuring out power management. |
If you need help getting down the track "power management" i might be able to help some. |
Good job to you and Calvin! Troy and Jimmy are good people.
Thanks. I'll need all the help I can get.
Paul,
Totally impressed with that whole operation. Those two guys are on top of their game for sure. Thanks |
Great Power.
What CV1 port was used? |
