Wheelie Bars
Sprung or Not Sprung?
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Not sprung
Wheelie bars
Not sprung
505 KRE HP head 2x4 HP 1000s 60' 1.33, 5.78 @ 120.88MPH in 1/8 9.11@149.8MPH in 1/4 |
What are the advantages of not sprung?
I run un sprung chome moly bars. They have enough flex. Don't need a spring on them.
Santhuff from Shocks, u won't need sissy sticks.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
My buddy I race with had unsprung bars on his car. They would hit hard enough that it would unload the tires, and broke a couple ring gears. He went sprung and really likes them alot better. What Jack said, a good pair of shocks and front end limiters will control most wheelies.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
I have Strange double adjustable on the rear.
What king of limiters?
I bought and mounted bars with springs, but decided to replace the springs with solid tubes. I was concerned if I left the springs in, the bars would hit the body. So far, the bars are working fine and I don't show any wheel unloading with the Racepak.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Jack is talking about front shocks not the rears. I put Afcos on the front of mine and it made a big difference over the QA1's that were on there. The limiters are basically a long bolt through the upper a-arm with a plate under it that will limit the amount of front end travel. You can adjust the amount the a-arm drops before it wants to pick up the front tires. The less travel the more it kills the wheelies. Same principle as tightening up the front shocks.
What is the rear suspension? Ladder bar, 4link?
Front shocks are more important then the rears.
Basically a stock 4 link set up.
