67 firebird both directionals flash really fast and no hazards any thoughts? Is there a second flasher somewhere? It has good bulbs.
Thank you! |
Generally it's usually the wrong flasher unit.
If it's a 'Heavy Duty' one, try the standard one. Would have to look up to see if there is another flasher. Later models usually had a separate one for turn signals and flashers.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
The directional signal flasher is on/under the dash, the hazards are on the fuse box.
Ill try those things.
Thank you for the help! |
ditto with johnta1. Try under the dash left of the ash tray area...and the other is fuse box
