Old 07-17-2016, 09:20 PM
CanAmT/AGTO CanAmT/AGTO is offline
Default Rubber Fuel Line routing from Fuel Pump to steel Lines
I have replaced the steel fuel lines from front to rear.
Both supply and return steel lines end just in front of the passenger side
Cross Member near the upper control bushings
Anyone have a photo of the rubber fuel line routing from steel lines to fuel pump?
You can see from photo below what I have.
Thanks in Advance
Larry
I Bleed Arrowhead Red,
64 GTO 389 Tri Power 4spd Nocturne Blue Poly
70 GTO 400 4spd Palladium Silver
75 T/A 400 4spd Buccaneer Red
71 T/A 455 4spd Cameo White
01 T/A Bright Red 4L60E Ram Air WS6
02 TA Navy Blue Metallic 6 spd Ram Air WS6
Old 07-20-2016, 09:53 PM
I thought it was strange that the supply and return rubber fuel line would route from the passenger side steel lines as shown in picture in previous post under the engine over to the fuel pump.
Not shown in the service manual, thought someone might have some input
Larry
Old 07-21-2016, 12:29 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
1970-71 metal fuel lines do cross over to the driver side. 1972-74 have rubber hose running under the engine over to the fuel pump . There is a clip on the timing cover bottom tab to keep the hoses from rubbing on the harmonic balancer.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 07-21-2016, 08:03 AM
Dens71TA,
I appreciate the info/clarification. Thank You!
