I already know this is being cheap. I was about to install a ring gear on the posi I bought and thought I would just use the ring gear bolts I had from an old open unit I had. They look perfect to me. Nicest bolts you'll ever see cause they were of course constantly dunked in gear oil as the ring gear turned.
Anyway, the instructions for my posi say to only use new ring gear bolts... Huh? Just wondering why. I re-use engine block cap bolts and head bolts without concern, so why is this an issue? Inquiring minds want to know. OJ
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Depends on the ring gear bolt size and the intended use. Have gone through or set-up R&P's multiple dozens on early 8.2's with the 3/8" rh thread ring gear bolts. With a 4sod and lower gears in the car, have always sourced new bolts for the reinstall . Refreshing bearings in a 2.78 or 2.93 geared early 8.2, have usually reused current ring gear bolts. Gray iron 8.2's, I wont blow bucks "upgrading" them for high torque applications, been there, they wont hold up, instead build up off an 8.5 A body hsg.
Almost every rear end I've done has been with used gears and I re-used the bolts that were in my carrier when I swapped them over. The only time I actually put new bolts in was when I used a ring gear spacer and it came with new longer bolts. Then I ended up re-using them when I changed the gears out a few years later.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
I'm probably going to live dangerously and re-use them.... if for no other reason, I just want to prove to myself this isn't an issue. When I look at our hobby today, I hear about all of the things we HAVE to do in building our cars, yet I recall 40 years ago when I had little money and built everything with discarded parts I scrounged from friends. In my old age I'm not much of a daredevil, so I guess I have to enjoy this kind of a big risk... LOL OJ
Put loc-tite on them, torque them to spec and call it the day. The only time I've ever heard of the bolts being an issue is from vibration loosening them up. The teeth on the gears usually break long before the series of bolts on the ring gear strip.
It's not a case of the threads stripping, its the heads popping off that causes a problem. GM, Ford and Chrysler wants the ring gear bolts replaced, whenever they are taken out, but what do they know? ; ) Doesn't matter to me, its not my car.
I was curious about this. I looked and I dont see that the 1967 or 1970 Pontiac service manuals called for replacing ring gear bolts while servicing the ring gear. If you do install with new ring gear bolts, one has to wonder are the bolts USA or ??? I just went through this and the new "grade 8" bolts I received had the grade 8 markings stamped off center.....
Probably the biggest danger in all of this is forgetting to torque all the ring gear bolts to correct spec. I tore apart a 8.2 BOP a few months ago that I got from somebody who said the rearend had a problem. I found that two of the ring gear bolts had backed out. It was a pity, they had installed Richmond gears.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. Last edited by TedRamAirII; 07-26-2016 at 10:09 AM. |
What are you torqueing them to that cause the heads to pop off?!?!?!? They only have a paltry 55/65 ft-lbs torque setting (8.2"/8.5") and the bolts are huge and fine thread.
And the "save money" logic doesn't really apply because it'd be dumb to find enough used bolts to put in new cars and how many warranty rear ends was GM anticipating doing? My bet is most rear end work was outside of warranty and it's another dollar they can charge to the customer.
He's my take on this.
One 3/8-24 fine thread grade 8 bolt dry torqued to 50 ft.lbs produces a clamping force of 7900 lbs. Torquing a 3/8-24 grade 8 bolt higher than 50 ft.lbs causes plastic deformation of the bolt. Plastic deformation causes the bolt to grow in length and shrink in diameter. My guess is that reusing an already plastically deformed bolt is not recommended as the longer length may cause it to bottom out in the blind ring gear bolt hole and the bolt is weaken due to the decreased cross section.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Being a geek who did all sorts of physics experiments in college I had the opportunity to test the tensile strength of bolts and actually did the elastic to plastic deformation tests. Your point helped me remember that lubricating a bolt lowers the amount of torque you can apply to it. The theory is the bolt will turn easier with lubrication, but is still stretching at the same rate as it would without the lubrication. So, in essence you will reach the point of "plasticity" at a lower torque level. It's not a small amount either. It could be anywhere from 10% up to 50% depending on the type of lubricant that's used. Seeing that used carrier bolts would have been continuously soaked in one form or another of lubricant and likely some form of posi additive, it would be hard to predict just how much the applied torque would change on a used bolt. Even if you clean them well, they can still retain quite a bit of oil on them (and for that matter, so can the ring gear threads). All this to say, a given torque on a dry bolt will have a lower load than on a well oiled bolt and that could be yet another reason not to rely on "used" bolts.
gtobird -what year and type is the rearend? What the 2013 GM service manual says is not going to apply to 8.2 BOP and 8.5. Newer rearends may very well have torque to yield ring bolts.
Maybe I'm living on borrowed time. I reused mine in about 1980. If I had $1 for every time I've dumped the clutch or speed shifted I'd be rich.
Great explanation on lubricant on the bolts though. I believe A fine threaded bolt will yeald a stronger clamping force than a coarse threaded bolt using the same torque. Use a torque wrench. I have a question. Can loc-tight act as a lubricant? |
In theory you could perhaps (maybe) prove the loctite thing by installing a new dry bolt and torquing it to spec. Draw a line on the head of the bolt and extend the line onto the part it's mating to after torquing. Try repeating this procedure to make sure the line on the bolt and mating part continuously line up after torquing. There probably will be small variation. Then apply loctite to the bolt and re-torque to the same amount and see if the lines still line up. If not, you know that loctite changes things. This won't be perfect science. When I did this kind of stuff in college we had a press with double acting cylinders, pressure gauges and a jig to test the actual loading from a given torque. Last, but not least even after all of this applied science, I'm still of the belief that there is little chance you will have a failure with used bolts. I say that only because back in the day our cars were built, most things were designed with a safety factor of 2X, but I can't argue with the logic that it's $10 worth of bolts to avoid a possible failure. OJ |
