Old 08-02-2016, 03:19 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Default Noise in engine bay
I am hearing a noise in the engine compartment that sounds like its either the water pump or the fan rattling around when I increase the throttle. No sound heard at idle. I did just replaced the Alternator belt and had to pry it on. I'm sure it's to tight and think they gave me the wrong belt. If I push in on one of the blades of the fan, the fan pulley moves about 1/4 inch or so. I'm wondering if a very tight alt belt could be causing the movement. I didn't notice the sound when running the engine without the alt belt on. Should the fan pulley have movement in it, or no movement? The car has sat for around 3 years and this is the first time starting it. If the fan pulley is suppose to have play in it, is there something that (sitting for 3 years) could/would cause the water pump to deteriorate? I'm wondering if I'm getting ready to have a pump failure and that's the noise I am hearing. Just curious to see if anyone else might have experienced this rattling sound before, as it might be something other than what I think it is.
Thanks.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 08-03-2016, 01:59 PM
transam greg's Avatar
transam greg transam greg is offline
Yes a over tight belt can kill a water pump bearing and seal. I say get another pump and the right belt.
Old 08-03-2016, 11:46 PM
dataway's Avatar
dataway dataway is offline
1/4" at the edge of the water pump/fan pulley (assuming the bolts are tight) means the pump bearing is trashed. Time for a new pump. And no you shouldn't have to pry the belt on ... it should go on easily with the Alt adjusted to the loose position.
Old 08-04-2016, 07:23 AM
If I grab the pulley I can move it up and down as well as side to side with movement around an 1/8 to 1/4 of an inch on all 4 quadrants. On the 69 Judge I cannot move its pulley at all, although it does have a different fan. The Judge has a flex fan/no A/C, and the standard 69 GTO has the standard A/C fan with the THERMO clutch. I'm guessing with the responses above I need a new water pump. Is this a correct assumption?
Thanks.
1976 Formula 350.
1968 Olds 442.
1971 TR6.
Old 08-04-2016, 01:41 PM
dataway's Avatar
Yep, new pump. Basically if the pump pulley has any discernible slop at all it needs to be replaced. The pump bearing is a pair of sealed ball bearings ... and should have zero slop that you can feel by hand.
