Back in 1983 I obtained a Pontiac unitized (hei) distributor from a fellow worker. Part number stamped on the distributor housing is 1112812 followed by a space and then 3L8. I found on another website that the 1112812 was used in 400 cube engines in 1973 and 1974 and that makes sense as the spark plug wires are marked 2Q 73. I'm assuming that the 3L8 is some type of date code as well. Can anyone tell me what the 3L8 means? Instead of storing it another 30+ years I want to sell it, however I want to be sure of what it is first.
Likely 3 Dec 1978. HEI wasn't around in 68.
Edit: Just found reference to Pontiac distributor date codes being year,month,day of month, not day of month, month,year like I thought. So yours would be 8th December 1973.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. Last edited by Bill Hanlon; 08-03-2016 at 03:47 PM. |
Date code is 1973, November 8th. Placed on a '74 vehicle.
Did they skip "I"?
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Electrical part didn't use the letter "I", so it wouldn't be confused with the number 1.
Thank you.
"I" and "0" are never used. Not just "electrical".
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Thought that was an odd statement as HEI WAS in use in 1978 so Unitized was not. ; )
Since you like to use blanket statements, I'll educate you.
"I" was used on cast parts such as blocks (except in '66 for the '67 model year), heads, intakes, etc. "I" was also used in window/windshield date coding. |
I stand Corrected! I misspoke, as newer VIN's do not have "I" as a character. But we were talking dates.
