1969 Pontiac GTO Judge Convertible, real GTO with judge option added. drove about 5000 miles since 15 year old frame off restoration that looks like it was done last week. Must see, no disappointments. 400 engine 366hp with #48 RA III heads, and RA exhaust manifolds, New Pypes S/S exhaust, rebuilt quick ratio power steering box, rebuilt muncie 4 speed with console and correct hurst shifter, 355 posi, rallye gauges, hood tach, power windows and locks, power top, no a/c, hideaways, power trunk release, am/fm radio, 15" rallyes, power front disc brakes, rear sway bar, front 1 1/4" sway bar.
Engine: '68 400 YS engine, cast #9790071, #48 RA III 3 speed heads, qjet carb, RA exhaust manifolds, pertronix ignition, 4 speed Trans: M21 3088336 case (cast) P9B17B (stamped) (1969 Feb 17th M21) 3925660 case (cast) 3846429 tail shaft# (cast) Rear Assembly - # 9785082 Date Code H 23 8 8.2" 10 bolt posi 3.55 ratio Frame: PARISH 3943347 8-22-69 1 Body: Vin# 242679B106476 Body Plate: 69 242767 BAL 507815 254 10 A 9B 0144479 $55k, this is not a car you will come and see and be fooled by the pics. It has not been thrashed together with incorrect parts, It was built to look the way in came off the assembly line, it also looks as good standing next to as it does in the pics.
thx, Percy |
