Old 08-18-2016, 01:24 PM
3goats's Avatar
3goats 3goats is offline
Default Help
Working on a 67 2+2 2-door with a bad window regulator drivers door. Does anyone know if a regulator from a 65 Pontiac is the same??
If not what fits? 67 only?
Thanks for replies
Old 08-18-2016, 08:24 PM
63gpman's Avatar
63gpman 63gpman is offline
I don't have a solid answer for you, but looks like the door glass is not the same.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 08-18-2016, 11:27 PM
Sirrotica's Avatar
If the teeth are sheared off I have welded them back up and made new teeth with a grinder and file. The newly made teeth lasted until the car was traded in many years later.
I would guess a 68 regulator would be the same as the doors look the same. Someone with an old interchange book (Hollander, Mitchell) would tell if they are interchangeable.
An older Pontiac parts book would also tell how many years the regulator will fit.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
