Old 08-21-2016, 10:15 PM
2manyT/A'S's Avatar
Default 67 and 68 speedo/gauge cluster differences...
Are there any differences in between these 2 years?
Eye Candy......garage band?
Go full screen & turn it UP!
Old 08-22-2016, 02:57 AM
blubomber's Avatar
blubomber blubomber is offline
No, I do no think so. both year had the same speedo options: std, SafeGuard, auxiliary gauges, and very rare aux gauges w/ SafeGuard. Both years used the slate blue grey back ground color. The wiring is interchangeable.
In '69 things changed. The speedo units went to a printed circuit board as opposed to individual wiring for each bulb or gauge used previously. '69 and '70 units are interchangeable except that '69 used the slate blue grey background color. In '70 they changed to a charcoal black color.
'69 Bonneville convertible
Warwick blue/ parchment interior
53 option accessories
2 more to go :-)
Old 08-22-2016, 11:49 AM
incommunicado incommunicado is offline
Default gauges
I have what I believe is a 69 rally gauge set in good shape if anyone needs one.
Old 08-22-2016, 01:13 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Don't forget the low fuel warning light! ;-)
'67 & '68 clusters are the same.
Old 08-22-2016, 06:13 PM
blubomber's Avatar
yes, on the gauges versions there is a low fuel indicator light (red) on the fuel gauge. They should have put that on all of them. Almost forgot in '69/'70 there is another speedo unit version that has seatbelt warning light
2 more to go :-)
Old 08-22-2016, 06:14 PM
blubomber's Avatar
How about a picture. PM me. thanks.
2 more to go :-)
Old 08-25-2016, 12:21 PM
mr67gp mr67gp is offline
My non-rally gauge cluster in my '67 wagon had a low fuel light. Timewarp has the car now, so I can't take a picture.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 08-25-2016, 06:16 PM
blubomber's Avatar
I did not know that. I wonder if all 67's had the low fuel indicator light and if that gauge could be swapped into a later model ('69 or '70 - color would be wrong) that did not have the low fuel warning light. Hmmm.....
2 more to go :-)
Old 08-25-2016, 09:08 PM
Ben M.'s Avatar
The fuel warning light is activated by a little round cylinder that mounts directly onto the back of the fuel gauge posts, so theoretically you could transfer it from one car to another. Maybe even get one from another model car like a Buick or Cadillac. Getting the light installed correctly would be the tricky part. The '67-68 full size clusters had a rectangular light hole and lens for it, perhaps a simple drilled hole in the actual fuel gauge where the LED\bulb could be mounted...
Old 08-27-2016, 05:45 AM
compsur's Avatar
compsur compsur is offline
Attached a couple of pics with Low Fuel on Standard and Rally Clusters
Name:	#1-Standard Cluster.jpg
ID:	435556   Click image for larger version
Name:	#4-Rally with SafeGuard.jpg
1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles
1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles
1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles
1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles
