Old 08-31-2016, 12:54 PM
70ra455's Avatar
70ra455 70ra455 is offline
Default 15" disc wheel vs. drum wheels?
I'm about to purchase the Scarebird kits for front/rear for my '66 GP resto.
However, their website says we must have "disc brake rims" ... I'm picking up my 15" Pontiac rims that were powdercoated today or tomorrow but I never was aware that there were disc brake vs. drum brake rims?
Am I crazy or will any 15" Pontiac rim work? Or can I tell whether the rims were disc brake or drum brake rims? Would disc brake rims work on a drum brake car? I ask that because the rims I got were from a drum brake '66 Bonneville that someone put the 15" wheels on.
Any pics of the differences would be appreciated. I'm trying to use the 15" rim and Pontiac poverty cap look.
Help!!! lol
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 08-31-2016, 01:48 PM
Tim Younker Tim Younker is offline
I did the Scarebird disk brake conversion on my 1962 catalina this spring. I thought I was good with my 15" steelies. NOT !!! My front wheels were off a 1956 pontiac (15x5.5) and did not clear the caliper. Very disappointing. I ended up buying front runner mag wheels keeping steelies on the back. Ended up costing me an additional $600. You might be alright with a later 15" steel wheel, IDK. Still glad I converted to disk though. I highly recommend going with Scarebird.
Old 08-31-2016, 02:17 PM
70ra455's Avatar
I will be HIGHLY dissappointed if I can't have the original look with the poverty caps or even spend the $$ and do he 8 lug 15" wheels (if they even fit.)
It would a hell of a lot better if Scarebird actually told you the clearance you need to clear the calipers rather than all this crazy guess work.
Just ordered them over the phone ...
Is there anyone who knows the clearance? I can measure my wheels when I pick them up.
Old 08-31-2016, 02:26 PM
The problem is here is where the caliper hits the inside of the wheel - either the center or hoop. A lot of factory drum rims have 14" centers - definitely a no-go.
Old 08-31-2016, 02:41 PM
70ra455's Avatar
what is the amount of clearance that I need in the 15" rims for the front and back brakes? Please give the measurement necessary ...
Old 08-31-2016, 04:17 PM
Stuart's Avatar
Stuart Stuart is offline
What car did your 15" wheels come from? The vast majority of them that you're going to find laying around are probably from late 1960s or 1970s cars which came with disk brakes in the first place. However, if they're old ones from the 1950s, or from the early 1960s (which will be rare) they may not fit.
Old 08-31-2016, 05:34 PM
70ra455's Avatar
They were on my 66 Bonnie that I sold ... I know that wasn't original ... I'm going to pick them up tonight ... I hope they work. I ordered everything for front/rear disc brakes from Scarebird and NAPA this afternoon. I'll be installing on the 12th ..
Does anyone know the space available on the disc brake rims? Would pictures tell you whether it was late 60's or early?
Thanks for your help!
Old 08-31-2016, 05:45 PM
63gpman's Avatar
63gpman 63gpman is offline
do you have any 14" rims around to measure inside the hoop to compare to the 15" rims you have? in 67+ they had 15" steel wheels for disc brake/HD Brake cars as well as the 15" rallys.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 08-31-2016, 06:57 PM
Deadhead's Avatar
Deadhead Deadhead is offline
If they do not work, it should not be a problem. GMC/GM truck rims also have the same lug pattern, and there are MILLIONS of them with the nubs for dog dish caps. Available for very cheap.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
Old 09-03-2016, 03:21 AM
70ra455's Avatar
I hope so. I'm shocked that Scarebird can't tell me how much room I need to clear the calipers since they tell me what rotors and calipers to purchase.
