Old 09-09-2016, 07:39 PM
70ra455's Avatar
70ra455 70ra455 is offline
Default 1966 Body Mounts
Hi guys:
Haven't updated in awhile and will do so soon with lots of pictures. The body is planned to go back on the frame on the 19th and I just looked at my original mounts to make sure I order the right parts from Ames (is there somewhere better to get the mounts?)
I noticed .. just as it says on the "parts search" that the openings of the mounts are 5/8" but the bolts for the mounts are 7/16" and don't screw into anything.
What am I missing?
Also, I lost 7 or 8 bolts and was wondering if anyone has original body mount bolts for sale or if you know where I can get exact looking repops. The Ames bolts in their picture are NOTHING like the originals.
Thanks for your help
Phil
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 09-09-2016, 11:35 PM
tharkun8 tharkun8 is offline
hey Phil..
I had the same issues on my 66 Vent.. I replaced all of the
body mounts and bolts .. since about half of them broke on removal..
I bought the entire set of mounts and bolts from ames.. I Compared
my old mounts to the measurements in the catalog.. determined
which ones I needed for a 66 4dr sedan.. and once i determined which
ones I needed.. The description of the mount tells you which bolt kit
to use for that mount.. that system seemed to work even with that
weird difference in the descriptions.
When I put my shell on and tightened it down at 4 points to go over to
the body man the new bolts locked into the existing cage nuts just fine..
on the ones that hadnt broken..
My body man had to cut open a few of the shell hard mounting points
to get the old cage nuts out to remove broken bolts.. as far as I know
we reused all of the original cage nuts..
I can call by body guy tomorrow to ask.. he still has my Ventura noses
to pick up.. (I had him clean and paint 2 .. so I have a spare) and Ill actually
be under the car tomorrow putting in the fuel and brake lines so Ill take a quick pic
if I remember.
John
Not all who wander are lost...
1964 Starchief 4 Dr Sedan - 389 4Bbl - Auto - Pinehurst Green/ Gold cloth
1964 Grand Prix - 389 4 BBl w SupHyd auto
1964 Catalina Safari - 63 389 200r4 auto.. 2.69 POSI rear
1964 Bonneville Vert - 389 4bbl - Auto - Ext Color - Saddle/Saddle int
1965 2+2 - WG 421 4Bbl - 4 spd - Bluemist Slate w White/black int
1966 Ventura 4 dr Sdn - 389 4Bbl - Auto -Orig Color - Barrier Blue
Old 09-10-2016, 01:46 AM
70ra455's Avatar
ah cage nuts! I don't see any in my bag of bolts and mounts ... and they're not listen with the mounts here on Ames ... do they come with the mounts?
Looking forward to seeing the pics ... thanks John!
Old 09-12-2016, 09:51 PM
I finally got the pics taken.. I never installed the fuel
lines so that changed my time around a bit.
hard to make out the mounts in the front corner
of the shell but there is a cage nut in there that takes
the bolt.
I hope these help at least some.
John
Name:	66 New mount1.jpg
ID:	436654   Click image for larger version
Name:	66 New mount2.jpg
ID:	436655   Click image for larger version
Name:	66 New mount3.jpg
ID:	436656   Click image for larger version
Name:	66 New mount4.jpg
Old 09-12-2016, 11:03 PM
70ra455's Avatar
Yeah I saw under there again tonight. My car has rotating t-nuts inside the body and the bolts fit right in ... Lord willing maybe Monday the body will go on the frame. We'll see! lol
