Horn Relay
I am installing a new horn relay on my 70 GTO. It has 4 terminals.I am trying to figure out what wires plug into each terminal. I have 2 of the wires figured out. They are the one that are in the same plug. What wires go. To the other 2 terminals. Anyone have a pic or can tell me..Thanks guys....Tom
http://www.forums.maxperformanceinc....d.php?t=794053
See if this thread helps you. |
I checked the thread out. I didnt see the tang at first on the end terminal. So on my wiring harness the black wire with white stripe goes on that because there is a groove o. The plug. So that means the other wire black with pink or red stripe goes on the other terminal. I hope this is right.
The black wire and the dark green wire are in one housing (brown) and are for the horn. The black w/pink stripe wire (notched single housing) is the key buzzer. And the orange [or black w/red stripe] (solid single housing) is the power feed.
From 70 SM for Tempest:
Schematic also
I'm 95% sure that on mine ('71) had 4 different types of plugs that could only fit in the correct place on the relay. I guess that's not the case for you.
I have it figures out.Thanks guys
