Old 10-07-2016, 09:51 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default fuel pump recommendations
Hi guys. What are you using for fuel pumps. Looking for 150-160gph. I currently have a Holley HP150. I street drive it so it may see 1.5 hours of street driving at a time. Noise is also another consideration. The HP150 has been enough pump and it's not too loud. But it failed and I'm looking for options.
Old 10-07-2016, 10:37 PM
Hooter's Avatar
Hooter Hooter is offline
I like Product Engineering due to the fact they are rated continuous duty for the street. Kinda pricey, but get what you pay for.
67 Bonneville ragtop
Old 10-08-2016, 12:02 AM
Rob B's Avatar
Rob B Rob B is offline
We just did Dragweek with the wife's car. We have a Mallory 140 pump with a return style regulator. Worked great, it's quiet, and affordable. Set pressure at 6.5 lbs and it never bounced, fluctuated at all.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 10-08-2016, 05:05 AM
Hooter's Avatar
Had this before the PE pumps. Gotta agree good pump for the money.
Old 10-08-2016, 10:37 AM
ta man ta man is offline
Another Mallory 140 here..I normally drive 100 miles to the track..I do replace the brushes each spring..I also have a older style Mallory 140 with access to the brushes from the outside...and I run it deadheaded for now..
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 10-08-2016, 12:51 PM
Thanks guys. I have been running the HP150 for a long time. I'm not dissatisfied with the pump. But we had one finally fail this week and am wondering what are some options. Are the Mallory pumps easy to repair?
"ta man. Another Mallory 140 here..I normally drive 100 miles to the track..I do replace the brushes each spring..I also have a older style Mallory 140 with access to the brushes from the outside...and I run it deadheaded for now"
Old 10-08-2016, 09:22 PM
NO67GTO's Avatar
NO67GTO NO67GTO is offline
Have a 155gph quick fuel deadheaded with a cheap Holley reg. No issues 500 miles so far
Sent from my XT1254 using Tapatalk
Giving To Others!!!
V.P. Pioneer Valley GTO Association
www.pvgto.com
67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008
68 GTO H.O. in progress?
Old 10-08-2016, 10:57 PM
FrankieT/A's Avatar
I don't like Mallory anything, but I had a 140 dead headed with NOS on a big block Chevy putting out about 550 horse before the NOS and it never gave a stitch of trouble. It worked flawlessly.
Old 10-09-2016, 01:24 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I've been running a Mallory 140 for 10 years or more. I had to put brushes in it once after running it for a couple years on a deadhead regulator. I switched over to a bypass regulator and haven't had any problems with it since. Hundreds of passes and thousands of miles including 3 Drag Weeks.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 10-09-2016, 01:45 PM
WARPed's Avatar
WARPed WARPed is offline
I had a Mallory 140 with supplied return style reg in the blue car when it went 6.20's/9.70's.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 10-09-2016, 08:11 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Also used a Mallory 140 dead headed in my 78 for almost 20 years had to replace it once.
Skip Fix
Old 10-10-2016, 08:31 AM
Rob B's Avatar
Yes. You can get a complete rebuild kit for one that comes with everything you need including the sealed bearing and brushes for about $50 or brush kits for about $20. I have one that is 15 years old that I just took off the wife car that was dead headed and replaced with a new 140 return style when we did Dragweek. I had never put brushes in that pump until I rebuilt it to take for a spare. Internally, the pump was in great shape.
Take the extra time and a few extra bucks and go to a return style setup if you drive the car on the street at all.
