Ran a new best with the D-ports today. 10.55 @129.4 Drove it there and back today had a real good time.
Congrats Scott!!! True10sec street car thats Awesome brotha keep up the good work....
CONGRATS ON YOUR NEW BEST EVER PASS.
I always liked DeSoto Dragway. That was/is Jimmy & Vic Keens Home Track. If you see them sometime tell them I said "Hello" and I will be retiring from Ford at the end of the year. Tom V.
Thanks, im pretty happy with the results I'm having with my car. I Haven't seen the Keen in a long time but I do know them my brother knows them pretty well.
nice job scott!
Gene Kinch 1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116 1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108 1971 GTO 400,t400 3.23 10 bolt all original 14.41@96 1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85 1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction) 1979 TA, 400/ 4 speed all original needs restoration. 1999 Trans Am LS1 |
Good job!
Change tires at the track or run the street tires?
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
Very cool, driven back and forth.
What's the combo? |
I drive it on Mickey Thompson ET Street. The new SS tire. They work as good as the old ET Streets did, at least for me.
Nice Job!!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
Good going Scott!!
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
Thanks guys. Alex, I'll most likely be putting the E heads I got from you on after the beginning of the year. Gonna just tune on these and see hi ow fast I can get it before I switch. Hoping to get into the 10.40s I think I could have had it there yesterday. I had 1 run that the 60' was good enough. But on that run I had fuel delivery problem. ( ran out of gas..lol..)
Cool job Scott!
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Weight and combo
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Very nice sir! That is a bad machine, well done.
If you did that with OEM iron D-ports, that's impressive.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Yes. Ported #62s. Using a victor, no port work to the runners. Actually I had to use epoxy to close up the runners. They were too tall.
Great to see you out again Scott. That Fbird looked strong all the way down the track.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Wow 10.50s @ 129 MPH is NICE Iron performance. Sell the E-heads, keep the Canolis.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Made it to the 1/8th mile track last night. Weather was good. And with a little tuning I got it to run 6.54 @ 104.26mph. Incremental were.
60'......1.47 330'....4.20 1/8.et..6.54 1/8mph..104.24 Pretty happy with the performance. |
Congrats Scott, the DA's had to be incredible with the cold air we are experiencing.
