New best
Had a good night last night at Gateway. Temp was 69 degrees.
11.58 @117.5mpg 1.69 60ft Thats rolling into it at the start. I know the 60ft is lame so The last pass I just mashed it and smoked the Tires. M/T drag radials 18psi 255/60/r15. 3900lbs race weight Nice way to end the year.
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
Slippage:
Pretty dam good.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
Very nice!! Car would be an killer run with my buddies 66's. Nothing wrong with a 1.69 60 foot on a some 255 dr's!. His just went 11.56 at 115.8....1.65 60 foot.
Link to the thread http://forums.maxperformanceinc.com/...d.php?t=795545
1969 Camaro 491 BBC/TH400/GV OD/3.50 Last edited by 6D9; 10-29-2016 at 01:25 PM. |
Good job!
Good numbers.
What cam? |
Thanks guys. It's SD's Ole faithful cam
Good job.
Congrats!
Very Cool!
Carburetor building & modification services Servicing the Pontiac community over 25 years |
Excellent!!
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
Awesome!Everybody is getting quicker love it!
Quote [ta man]Awesome!Everybody is getting quicker love it.
X2 ...nice to see . Feels pretty good when all the hard work etc pays off. If you can get that 60 down there are 30s in the combo.. |
Ditto what everybody else said. Always a great feeling when you can make an improvement.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
Awesome nice run ....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
