Took the pile of used parts to the track last night. Only change I made was go from a 750dp to a 850 dp. The car went from a best of 7.78 to 7.57 and picked up 2 mph. The car made three passes and I also had had some good lights. So it was a good night.
Very nice! Post up some car details if you haven't already.
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
Don't really have a lot af details. It was a project someone got tired of . I bought it and finished it up. here is what a can tell you.
455 6x heads Torker 2 intake ( I had to shave 60 thousands of to get it to fit) Hydraulic cam. I don't know the spec's. 1.65 roller rockers Motor has been balanced . Stock rods Turbo 400 manual valve body and about 3400 stall 3 inch exhaust to mufflers and 2.5 tail pipes 12 bolt rear. I am guessing about a 4.11 or 4.56 gear. I am shifting at 5200 and going through the the traps at 5400 in the 1/8 |
I think the converter is wrong for the car.
Nice!
Thanks Paul.
Congrats!
Nice pick up in ET on the carb size increase. Try a Dominator next? ![]()
I have a 1150 and a warrior intake ! Might be a little big. I think the biggest problem right now the converter.
Good times!Are you running a spacer?
I have a 1 inch open spacer on it.
60' is good.........I'd keep the converter, and drop the gear to a 3.73!
I think it is slipping in High gear. Not sure yet something I need to keep a eye on.
so I did some calculating and it looks like I have about 26% converter slippage. Not to good when it should be under 10%. The converter is also flashing around 4200. Since I am shifting at 5200 , I think it's kinda much.
What rear gear did you use to figure converter slip? And what size tires on the rear?
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
I used 4.11 . That is what I was told was in it. But I haven't checked it yet so I am not 100% sure. The tire is a 275 drag radial.
Nice! Good 60ft
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ![]() ([_|_] ##\|/##[_|_]) |
Gotta jack that thing up and do the drive shaft count.
What it's doing now is close to having 4.56 with 10% converter slip.
I did that and it was right at 4 . 5400 at 88 mph seems real high to me. I need to jack it up and pull the pan and count teeth.
How tall are your tires?
