Old 11-11-2016, 02:32 PM
CatnDoo's Avatar
CatnDoo CatnDoo is offline
Default Ram Air IV Valves - One or two piece valve
Hi All
I seem to be getting differing answers to this question:
Are Factory Ram Air IV valves a one or two piece valve? In addition, what tells us its one way or the other?
Cat
Old 11-11-2016, 03:10 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Factory RA IV valves are two piece. I broke a couple before I switched to aftermarket.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 11-11-2016, 06:14 PM
Formulas's Avatar
Formulas Formulas is offline
I kinda wonder if all the broken valves were in a near stock configuration or if 300lbs seat pressure was involved.. ??
Old 11-11-2016, 06:22 PM
WDCreech's Avatar
.520" lift Crower hydraulic cam and springs back when I was still doing the street/strip thing.
Bill
Old 11-11-2016, 07:00 PM
Tom Vaught's Avatar
Boost Engineer
Jim Brady broke a RA-IV valve (two piece) after a burn-out in the box as he was idling up to the starting line at Broadway Bob's track in Wisconsin.
The head came off, flipped over, and the engine stopped. Locked up. (Hint: if the engine stops suddenly, do not crank over the engine. Put a 15/16" socket on the crank and try to bar it over first.) By doing this, Jim was able to remove the head with no damage to it, replace the valves with one piece valves, and inspect the thick top (heavy) forged TRW piston. Piston was fine, rod was fine, bearing was fine. VERY LUCKY guy, Jim B!
So I will never run a RA-IV valve in any performance application based on that deal.
Tom V.
Old 11-11-2016, 09:35 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I also agree they are 2 piece. One way you can tell is to run a magnet down the stem. If it sticks to the stem, then suddenly doesn't stick anymore near the head, it is a 2 piece valve. Also 2 piece valves usually have a bulge in the stem where the head is friction welded to the stem. They make them 2 piece because that way they can use a very high heat alloy for the head, and combine it to a stem that can be a lot more wear resistant.
2 piece valves have no place in a performance engine. Had one destroy my 428.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 11-12-2016, 05:12 AM
dataway's Avatar
dataway dataway is offline
Years ago had my 68 YS valves replaced with 69 ram air valves ... the exhausts had magnetic stems and SS heads ... so I assume two piece.
Old 11-12-2016, 07:11 AM
steve25 steve25 is online now
If your rebuilding a RA4 do use RA4 type tulip Intake valves as they really don't flow any better under dynamic conditions and only add weight to the valve train. If you don't belive me then ask yourself why Pontiac did not use a tulip type Intake in the 455SD, or why the aftermarket heads don't use them!
Old 11-12-2016, 08:50 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Pontiac did use a tulip intake valve in the SD 455 engines. Visually it's almost identical to the RAIV valve but has a 45° valve face and it's shorter.
Go fast, see Elvis!
Old 11-12-2016, 11:08 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My RAIV heads and another set I flowed picked up 5% just using a flat D port style intake valve.
Skip Fix
Old 11-12-2016, 11:19 AM
Half-Inch Stud's Avatar
I've bough a couple sets of NOS RA IV valves, Gm boxed, number stamped up near the grooves. Magnet deal will reaveal the answer. They all stayed together for my S/Strip use.
A 71 455 HO didn't have such fortune when an exhhaust valve dropped head during an autocross event. So, those forensics (and some Other folks experiences) got me affording 1-piece valves.
Differing alloys get a weld... Friction-Weld?
New one piece valves are supposed to be the assurance of staying together.
Old 11-12-2016, 01:49 PM
gtofreek's Avatar
I believe you meant DO NOT USE. I have found the same thing, the tulip valves hurt flow. They flow better with the 12° flat valve, and even better with a 10° flat valve. I feel a lot of it has to do with the flat floor of the chamber.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 11-13-2016, 07:26 AM
Sorry , ment the round port HO heads.
Old 11-13-2016, 07:41 AM
wovenweb's Avatar
wovenweb wovenweb is offline
Does this apply to the intake side only?
Old 11-13-2016, 01:42 PM
1968GTO421's Avatar
Sounds like one piece after market valves are the way to go. But which is best (or are all pretty much the same)? There is Manley, Milodon, and Ferrea. Maybe others I'm unaware of.
GTOAA--https://www.gtoaa.org/
Old 11-13-2016, 02:27 PM
gtofreek's Avatar
I like the Ferrea valves the best. Their quality has been top notch. Ferrea's usually flow 5-10 CFM more also than some of the Manley valves because Manley uses a larger radius from the stem to head transition[3/8" compared to 5/16" for Ferrea]. The larger radius takes up space, thus reducing flow.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
gtofreek's Avatar
Intake side as IIRC, the exhaust side still uses a flat valve.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 11-13-2016, 02:31 PM
gtofreek's Avatar
Also, I have seen Ferrea valves stems bent all the way around into a spring shape without breaking the head off. I have seen other brands of stainless steel valves break the heads off after being bent 45° or less. In all my years of using hundreds, if not thousands of Ferrea valves, I have only seen one break the head off. It was from thermal shock. I have seen a lot of other SS valves break heads off.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 11-13-2016, 04:38 PM
Tom Vaught's Avatar
Boost Engineer
I have been buying the Ferrea Valves from the guys in Florida since 1997.
Good people and as was said, Quality of the parts is Top Notch.
Tom V.
Old 11-13-2016, 08:59 PM
1968GTO421's Avatar
Thanks, Paul. Much appreciated.
https://www.ferrea.com/
