A couple of questions
Does anyone have a photo of the correct factory installed fuel/brake line clip(s) that attach to the frame on a 1967 GTO? Having a heck of a time figuring out how to run the lines from front drivers side to the rear. The repro assembly manual I bought has such tiny font and pictures...plus the re-print is faded which makes it that much harder to see. Any photos would be greatly appreciated.
Also looking to get opinions on the best rear axle bearing/retainer set on the market for a 10 bolt 28 spline 'bolt in' style axle (no C clips). Would love to find an American made product if possible. I bought an NOS NAPA bearing/retainer but need one more for the other side. Thanks for any knowledgeable input you're willing to give me. Robert |
The fuel/brake line clips look like this. The fuel line (larger) snaps into the larger part, and the brake line into the smaller opening.
they run on the inside of the frame rail, on the driver's side. I think you need 4 of them. Hope this helps. |
Thanks again. Robert |
The toughest part of running a new pre-shaped fuel line, in my opinion, is getting it through the frame rail. I ran a wire coat hangar from the front where the line emerges frame the frame, back through to the opening where it emerges. With a pair of needle nose I carefully fashioned a loop in the coat hangar around the forward end of the line. I then fed it into the frame rail, intermiitantly pulling very gently on the coat hangar until the line emerged. Pull it as far through the rail as you can, even beyond where it will eventually stay, as you'll need the extra clearance to get the line over the rear end without kinking it. The you can snap it into the clips once it's in place. I don't know the answer to your question about three lines; mine only had two running to the rear.
Save yo Confederate money, boys, the South is gonna do it again! Pecosbill |
Could that 3rd line be a brake line?
Mine has 2 fuel and 1 brake line in that location. I redid mine but what was on the car may not have been original.......
George
Took these pictures over 30 years ago of my '67 convert. The tags say "S & L" for small and large fuel lines and "B" for brake line. Both of my '67' have 2 fuel lines, the small one is a return line.
Bill Nawrot (Wino Bill) 1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019 Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/ YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU 1967 GTO Conv |
Yes, I should've thought of it before my earlier post. AC cars had a fuel return line running back to the gas tank.
Neither one of my '67's have AC but they still have a return line.
That may well be the case; I'm going off of knowledge of my 64 where only the AC cars had the return line, although I think the tripower cars may have also had it.
Thanks to all who responded. A special thanks to YNOBIL for the clear pictures. Just what I needed. Mine is a hardtop which is slightly different because the frame is not boxed...so the clip location is not the same...but the location of the lines is very important. I really appreciate your help.
Robert |
A couple more questions!
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
Is this the correct exit hole?
That looks to be correct, but I am out of town currently and away from my car to verify. The lines should emerge fairly close to the fuel pump.
Yes that looks correct.
Thanks again to all who responded. With your help this project is making headway. I bought a 1 1/16" rubber plug with 2 holes in it to secure and separate the fuel lines from the bare metal on that exit hole. Not factory correct but adds a finishing touch as well as function.
Late model year '67's all had the vapor return line regardless of a/c or non a/c. The problem of vapor lock was later resolved in future years by a return line to the fuel pump instead of all the way back to the tank.
In non original applications, the fuel pump return seems like a better option |
