Old 11-23-2016, 01:53 PM
4RSFEDGTO's Avatar
4RSFEDGTO 4RSFEDGTO is offline
Default E85
How many of you are running e85 with boost? What's the combo and amount of boost and are you intercooled?
Mike Bright
Special thanks to Mark Luhn at Luhn Performance for all the help
Old 11-23-2016, 02:46 PM
charlie66's Avatar
E85 38 psi 8.75 to 1 and intercooled
My Half AN Injun.....
Old 11-23-2016, 02:50 PM
4RSFEDGTO's Avatar
Awesome! Is it turbocharged or supercharged and what size?
Mike Bright
Old 11-23-2016, 03:17 PM
charlie66's Avatar
Turbo PT6870 .81 AR....
Old 11-28-2016, 09:58 AM
Curious George's Avatar
Curious George Curious George is offline
498 blow through on E85 up to 14 psi non intercooled
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 11-28-2016, 12:24 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
EFI, Turbo, air / water intercooler, 8 to 1 compression, been running up to 18 psi on the street with E85 for 3 years.
Lately the boost controller has been acting up and boost has been 25psi in and out of the throttle, engine is still just fine.
Old 11-29-2016, 01:52 PM
GTOGEORGE's Avatar
Seems to me you really wouldn't need an intercooler with E85.
GTO George
Old 11-29-2016, 05:45 PM
4RSFEDGTO's Avatar
I've been told the same about not running an intercooler.....
Mike Bright
Old 11-29-2016, 07:20 PM
Under 15psi and carbureted with E85 I wouldn't worry about an intercooler unless you really plan on pushing it. Just my opinion. Hoping to log my IAT next year.
Old 12-22-2016, 05:51 PM
er455 er455 is offline
How much timing are u guys running with say 15 to 18# of boost
Old 12-23-2016, 02:10 PM
v869tr6's Avatar
I think mine is at 21 degree's at 18 psi
Old 12-24-2016, 12:17 PM
Torment's Avatar
Torment Torment is offline
E85, 20PSI measured in the manifold below the hat injectors, and before the ports - about a 50/50 split.
https://m.youtube.com/watch?v=CqQQF-4Vwyc
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 12-24-2016, 03:53 PM
charlie66's Avatar
So your air tems go down on a pass . Wow! Is it intercooled ??
Old 12-24-2016, 05:46 PM
Torment's Avatar
Whipple charger - no intercooler. Yes that was my take-away too.
Old 12-24-2016, 05:48 PM
charlie66's Avatar
impressive!
Old 03-20-2017, 01:57 PM
Default Timing and boost
Ok I are you guy running your timing locked out or are you pulling timing with a retard box gradually?
Old 03-25-2017, 01:42 PM
Torment's Avatar
I control timing with a Power Grid, RPM based. With the positive displacement supercharger boost response, for practical purposes in my application, is instantaneous. Therefore I have no need to ramp versus boost rise. Your application could be different.
