Old 11-26-2016, 08:26 PM
Hotrodizz Hotrodizz is offline
Default 1971 T37 door panels or just trim needed
Need 1971 T37 2 door, door panels for cores, or just the aluminum trim that runs along the top of each panel.
Old 11-27-2016, 07:31 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
I have these door panels $20 plus the ride.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 11-28-2016, 10:38 AM
I appreciate the offer, but the 71 Panels are different, and they have a removable upper molding.
Old 12-03-2016, 11:34 PM
py71lemans py71lemans is offline
I have 1 pass side. Do you just need part of it?
Old 12-05-2016, 01:06 PM
tripower's Avatar
tripower tripower is offline
Those look like 71 Lemans.
You can interchange 72 Lemans Door Panels with 71 T-37, GT-37 if that helps.
Norm J
Old 12-05-2016, 01:12 PM
I appreciate it, but I am trying to be "correct". I had SMS Auto Fabrics make the panels for me, but they lack the aluminum molding that runs along the top. They also made the rears with the incorrect upper rail, but they are re-doing those now. Anyway, I ordered a set of 68 GTO moldings through PUI, and I am confident they will be the correct lengths.
Old 12-05-2016, 03:39 PM
tripower's Avatar
The front and rear door panel bright trim on T-37 are actually stainless steel. I may have an extra set in storage I will check.
Norm J
Old 12-05-2016, 03:48 PM
OK, thanks.
Old 12-05-2016, 10:53 PM
CraigGT37's Avatar
CraigGT37 CraigGT37 is offline
I may have a set on a set of old panels i have. I can check also if you havent found a set yet.
Old 12-05-2016, 10:57 PM
Thanks guys
