Old 12-01-2016, 09:06 PM
Jacob69gto Jacob69gto is offline
Default Motor mounts or mid & front plate?
. Having a new motor for my 69 gto built and will be making about 750horse.don't know If I need a mid and front plate or to go with butler performance heavy duty rubber mounts.car is street strip.and don't want solid steel motor mounts
69 gto,538ci all pontiac.com block. Th400 trans break.
Old 12-01-2016, 10:32 PM
ponyakr's Avatar
ponyakr ponyakr is offline
If you don't mind the vibration, go with plates, or at least a rear plate.
Just curious, with the aftermarket block, why would you consider plates, but not solid mounts ?
Old 12-01-2016, 11:37 PM
Just heard bad things about solid.( breaking the mounting bosses of the block) .maybe I'm wrong ?
Old 12-02-2016, 12:06 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I used to run solid mounts with a front plate. I have never had and issues breaking blocks even with just the solid mounts.
With a front/mid plate you need to consider limiter bars to eliminate lateral movement.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-02-2016, 01:56 AM
Old Man Taylor's Avatar
I went with elephant ears up front and a poly trans mount. No mid-plate, and no mounts on the side of the block. For one thing, the mounts would not bolt up to my IAII block. The flat wasn't machined high enough. It's been working fine for years.
Old 12-02-2016, 08:36 AM
charlie66's Avatar
I have solid on both my cars with no issues..
My Half AN Injun.....
Old 12-02-2016, 10:23 AM
PAUL K's Avatar
PAUL K PAUL K is offline
I use a solid on the drivers side and factory on the other side. I'm sure plates would be better.
Go fast, see Elvis!
Old 12-02-2016, 10:59 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Solid mounts for 10 years, no problems.
Old 12-02-2016, 01:28 PM
WARPed's Avatar
WARPed WARPed is offline
Not that you are likely to do so but if you go with a front plate do not use any part of the heads as a mounting point.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 12-02-2016, 02:09 PM
Hey WARPed what are you using on your 535?
Old 12-03-2016, 11:11 AM
gman005's Avatar
gman005 gman005 is offline
I run a front and mid plate on my 535.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
Old 12-03-2016, 02:29 PM
BADDTA's Avatar
BADDTA BADDTA is offline
We've been running solid mounts with no issue so far. Going to install an all Pontiac motor plate this winter. Trying like hell to save the factory block when we spray it next year.
Brian
Boobs & bacon
Old 12-03-2016, 02:48 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
I use motor plates front and mid and poly trans mount. The plates makes routing large tube headers easier.
Old 12-03-2016, 08:15 PM
70 bird's Avatar
70 bird 70 bird is offline
Solid mounts here, 10 years no problems.
Old 12-05-2016, 08:51 AM
steve25 steve25 is offline
If your making over 700 hp on factory block you should not use the side motor mounts , as that is what is partly responsible for the blocks cracking down the middle the way they do!
