Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
JE Wrist Pins
Senoia, GA 30276
JE Wrist Pins 5115 Low Carbon Steel Straight Wall Pin Sharp End Diameter .980 Length 2.750 Wall .15 JE Standard high performance wrist pins are made from premium 5115 low carbon, case hardened steel. Perfect for high performance street/strip applications, these pins provide maximum strength and minimum weight. How to read JE Pistons Wrist Pin Part Numbers: First three numbers: Diameter of Wrist Pin (example: 927 would equal a .927 diameter) Second set of numbers: Length of wrist pin (example: 2930 would be a 2.930" length pin) Third set of numbers: Wall thickness (example: 14 would be a .140" wall thickness) Forth set of numbers: Series/Material (example: 51 would be for a series 5115 low carbon steel) Last Letter of the part number: Lock Type (C=chamfer end which is designed for wire locks only and S=Sharp End and are designed for spiro type and true arc locks) Features Diameter: .980" Length: 2.750" Overall Length Wall Thickness: .150" Material: 5115 Low Carbon case hardened steel Lock Style: Sharp end for Spiro Type and Tru Arc Locks part number is in photo below. $65 plus shipping
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
