Washing before painting q
I am getting ready for paint, my question is what are your thoughts on washing the car to get all the sanding dust out. I have heard some wash with a small amount of dawn in the bucket. Thoughts?
1970 gto (4spd) 462 500 hp 11.940@114.21 / 1.843 60'/ 3980 lbs 1964 corvette roadster 1968 corvette roadster 1962 corvette "equal rights, not equal things" if you want to know the future, read "atlas shrugged" I dont race a 4spd because it is easy, I race a 4spd because it is hard. |
Nevah done that.....PPG sells a waterborne pre cleaner to remove primer residue and other contaminants before top coating.....and wear rubber gloves when doing this step...you don't want the oils from you hands on the surface. Don't know if they sell it quarts.
I always blow it off with compressed air and then wipe it down with pre-clean. Never have tried the water borne stuff. Always wear gloves.
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
I have washed it off with water and a detergent ( e.g. dawn or similar) but only when the weather is warm or hot (or a very warm paint booth).. it HAS to thoroughly dry EVERYWHERE after that..then I wipe it down with a w.g. remover..I'm sure others have their own way.. preferences..good luck on your painting!
I use the water Bourne cleaner...cus...some/most of the aftermarket bumper covers are primed with water Bourne ......just once ,way back ,I used a solvent based cleaner and wiped the primer off !
