SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 01-02-2017, 01:40 PM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default Used 1960 536109 425A Heads & M4 Block
1 used 536109 High Compression head, has the x & o stamped above the casting number which means it came off of a 425A 389 Tri-Power engine with 348 HP & 10.75 Comp. Ratio. Comes with the valves & rockers but no springs. $100.00 + shipping. I have the other head but it is hurt. $25.00 I also have the Block these were on, it`s a 425A 389 Tri Power Block, M4, 4 bolt main, it was also hurt & needs a sleeve. $350.00.
ID:	443944   Click image for larger version
ID:	443945   Click image for larger version
Old 01-04-2017, 08:44 PM
Default M4
Also have the Arma Steel crank from this engine. #531369 !00 clams + shipping. Timing chain cover 50 clams, balancer 25, upper & lower pulleys 40 clams. + shp.
ID:	444172   Click image for larger version
Old 02-09-2024, 12:34 PM
drain89 drain89 is offline
Are these still available?
Old 02-09-2024, 02:57 PM
Default gone
No everything is gone.
