Old 01-15-2017, 05:26 AM
plate plate is offline
Default -67 Bonneville
Hi
Got problem with my heating... Cant turn it either way, cold or hot. From dash, knob wont turn. Found out cable is leaving from there. Anyone knows where is going?
Thanks Mikael
Old 01-15-2017, 06:51 PM
perryka's Avatar
perryka perryka is offline
Mikael,
The temp control cable goes over to a cam mounted on top of the heater core unit. That cam controls the flapper door in there. If you take the glove box out, you'll be able to see it behind there. Cable could be kinked or jammed up, or just gummed up with dried crud. Might need to be cleaned and lubricated. If you remove the end of that cable at the dash control unit, check to see if the control knob and slider behind it are moving freely. You should be able to determine what's going fairly quickly. Let us know what you find.
Alan
Old 01-16-2017, 06:10 AM
Originally Posted by perryka View Post
Mikael,
Alan
Yes.
I found out, cable was ok, flap was bit stuck. I had remowed dash and glowbox too. Then was able to do it. Had find rear pw cables too. to do that remowed under pad under dash, and box wich is front off heatercore. I should do it first, now was able too all heater links. Thanks for advice.
