Old 01-18-2017, 07:31 AM
Tim john Tim john is offline
Default Firebird front bench seat ?
HI all, good morning. I have a question in regards to the front bench seat in a Firebird. I found a 68 front bench (have not seen it in person yet), my car is a 69, are the seats the same except for the vinyl material & foam ? Can I take this 68 seat and recover it to make it correct for my 69 (and foam if necessary). My car has deluxe interior also. Is the 68 & 69 frame the same, never taking one of these front benches apart before, are the seating areas just a bucket foam with some padding in the middle to make it the bench or is it a one piece foam. What I am getting at is can I take a 68 front bench and make it correct for my 69. If I have to replace the original foam, does one use the deluxe bucket foam for replacement ? Seems like you could by looking at it. I also posted this inquiry in the first gen section. Please advise. Thank You.
Tim john---
Old 08-14-2025, 12:20 PM
tininjun68's Avatar
tininjun68 tininjun68 is offline
@Tim john, I know it's been a few years but how'd it work out with the front bench recover? Any pics?
You know me, "Safety Forst"
68 GTO-Verdoro/Black/Black, what else was available in ‘68? Has to be longest resto in history.
69 GTO Vert-Liberty/Blue/White Top, 4spd, match #’s
68 Mustang FB-Green/Black (Bullitt)
Old 08-28-2025, 05:53 PM
rambow rambow is offline
I'm not Tim, but I have redone a 67 bench before, and a ton of seats.
Yes to Tim's question, you definitely can make a 67 or 68 bench into a 69 bench, but you won't have the receiver tube for the 69 headrest. If you can get/find one it would not be a big deal to add it to the earlier frame.
You may have to move/adjust the spring side listing rods for the specific seat cover pattern you are using, but thats not a huge deal, just be aware that it will need to be done when switching years/styles.
I used ACI bucket buns, Complete/as-is for the upper cushions, then for the lowers i cut them apart at the inner bolsters, layered in a section of 2" HD sheet foam in between(glued together with jute underneath)
Worked out great:
ID:	656310   Click image for larger version
ID:	656311   Click image for larger version
Old 08-29-2025, 12:07 PM
Cammer-6 Cammer-6 is offline
From what I remember the upper seat back was same as bucket seat so just use that from a 69.
69 lower was widened a little on the bucket seat,dont remember if the bench was too.
I have a 69 bench apart somewhere,sent to PUI many years ago for patterns.
PUI took them apart,then told us they werent interested.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
